Question about Sony Handycam DCR-DVD201 DVD Camcorder
Format Error As the dvd was almost filled I got a "format error" What should I do? Thanks
  • 6 more comments
  • nans85 Oct 11, 2008
    want to view or finalize disc and format error comes up
  • Anonymous Nov 01, 2008
    format erorr wehn the dvd was almost finished
  • avillar Nov 16, 2008
    the disc got full and Format Error showed up. The disc is also Sony.
  • jbarnes1996 Dec 26, 2008
    Was recording Christmas and format error came up. Won't let me finalize or play. Has anyone found a solution yet?
  • Anonymous Jan 03, 2009
    me too!
  • Anonymous Jan 18, 2009
    I have the same problem! I just finished recording my daughter's graduation project and after finalizing we tried to play it back, first on the dvd player then on the camera and all I get on the camera is Format Error.
  • wkschulze Jan 18, 2009
    I just finished recording my daughter's graduation project. The disk is almost full and after finalizing the disc all we get is Format Error. HELP!
  • Anonymous Apr 19, 2009
    We have the same problem , got a format error after recording and not finalizing.
Posted on Nov 01, 2008
I have a Sony Handycam DCR-DVD92 and used a Son DVD-R 1.4 GB and received a C 13:02 error. I can not review my video in the carmera. Can you help me recover my video?
Thanks,
Stacie
Posted on Nov 23, 2008
2 Suggested Answers
  • 41 Answers
SOURCE: Format Error
First option would be to attempt to read the disk in another DVD player, for example on a PC. If that succeeds then transferring the data can be done via the PC. Another thing to try is to reset your Camcorder - refer to the manual to locate the switch and then try again. If neither works then re-formatting is probably the only answer. Always format the disks in the camcorder - not elsewhere.Good luck.
Posted on Jun 19, 2007
HARDDRIVE ERROR ON SONY RDRHXD860 DVD RECORDER
http://www.avforums.com/forums/attachments/blu-ray-dvd-recorders-media/68631d1198812029-succesful-upgrade-hdd-rdr-hxd970-how-upgrade-hdd-sony-x70-series-dvd-recorders.pdf You shouldn't use a computer to format the drive as the dvd recorder will do that for you.
Oct 25, 2012 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Audio error
Did you drag the video and audio files.
There is no reason to format a dvd-rw, if you want to use it again
just delete the files on the disk, if you format it, you could cause it to stop working or not accept files.
You format a hard drive to change format, or install a OS.
You don't use format on CD or DVD's just to erace them.
Nero also has an erase option.
Feb 09, 2010 | Computers & Internet
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Rear Seat entertainment Volvo XC90
Hi
1) Make sure the discs you are using fit the correct format specified by your Unit . For example - if you are using DVD-R's that you have burned yourself and the unit does not support this format you will get this error.
2) Dirty laser lense causing the unit to have problems in reading the disk. Use a cleaning Disk like this one to see if the error resolves.
http://www.amazon.co.uk/Hama-DVD-Laser-Cleaning-Disc/dp/B00005UPDF
If the error remains and you feel confident to do so you can open the unit and look for the glass laser lense - usually blue in color under the DVD clamp. Use a cotton swab and some isopropyl alcohol to gently wipe the lens in order to clean it.
Allow to dry naturally for a couple of minutes before re-assembling the cover on the unit.
3) Try a CD in the unit - if the unit reads CDs and not DVDs - this is an indicator of a faulty or misaligned drive mechaninsm within the unit itself. In this case the drive unit will require service attention and need to be replaced.
Obviously you should check that any disks you are using are clean and free from scratches.
Hope this helps. Please do rate my answer. Many Thanks.
Aug 04, 2009 | Audiovox D1708ES Car DVD Player
I have a HANDYCAM SONY DCR-DVD 106, and I keep getting the following message error - "Disc error. Unsupported format - 13:023, with regard to a mini MEMOREX DVD-R.
Disc error. Unsupported format means that ur camera does not support the format of this disc it might not support DVD-R or DVD-RW and supports the DVD+R and +RW try the other format disc and let me know if it resolved , check the manual it is stated on the box or manual which format it supports, if it does not solve ur problem try some other brand instead of MEMOREX try sony,hp,fuji,philips and see actually these sony cameras they are sometimes locked by the manufacturer to only use the original discs for monopoly sony acts like that in every product
pls do rate me if i fixya problem
regards
Zohail
Feb 23, 2009 | Sony Handycam DCR-DVD205 DVD Camcorder
Sony DCR DVD101 Format Error
I had the same problem, but I didn't have any valueable data on the DVD-RW (which was a Sony brand disc, go figure...). So, I backed up all the videos on the disc, tried to format the disc to get it ready to be able to be used again, and got the whole "Access Error" when I was formatting the disc. I tried both the VR and Video format options, the Video option came back with teh "Access Error" while the VR option came back with "Format Error". I put the disc into my DVD burner in my computer and was going to try and format it manually. But, as the disc popped up in My Computer and I right-clicked on the disc icon, there were no options to format the disc, which is unusual. I tried it in a laptop that's about a year old (versus the other computer which was about 4 years old), and as I right-clicked on the disc, an option was entitled "Erase this CD-RW". Obviously this was not a CD-RW, but I tried it anyways, and bam, after about half a minute, the mini DVD-RW was formatted! After that, I put it in the Handycam DCR DVD101 drive, formatted it using the Video setting (my preference), and now it works.
So, moral of the story is...try and format the disc manually on a DVD burning enabled computer. If it doesn't work, try a newer computer. But that's all I have, hope this helps!
Jul 10, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Format Error
Jun 19, 2007 | Sony Handycam DCR-DVD403 DVD Camcorder
Sony Handycam DCR-DVD201 DVD Camcorder Logo
905 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
