Question about Black & Decker CTO100 Toaster Oven with Convection Cooking
The temperature contol switch doesn't work. The toaster control works and turns on the burners, but the actual oven/temp control doesnt work. i would like to buy a replacement part. Where would I be able to order one from. Thanks Tom Marshall
SOURCE: Black & Decker Toaster Oven Model TR01000-TRO4000
I honestly believe that the burned element in my toaster oven is replaceable
like a burned out oven element or dryed element. I thought someone would
show me how to replace the element. That didn't happen. I am dubious
about the need for experts via a commitment to a specialists' plan.
Peter Olevnik
Posted on Dec 21, 2008
cactus bob
  • 267 Answers
SOURCE: Black & Decker toaster oven TR0651-- --
your right it is the thermostat , the problem is it cant be changed its rivited in place second ,theres no place to get it unless take a trip to china . its a toss it world ...... if you do send the plug , other people are waiting over 9 months and still no oven . so you may want to buy another one and use (if it ever shows up ) the replacement as a backup . and you will need it . no (any brand) toaster ovens are lastring over 2 years anymore .... good luck , you will need it .....Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 04, 2009
SOURCE: toaster oven door will not close completely.
Open the door and spray a little WD-40 into the vertical slot on the left near the hinge. Wait a day for solvents to fully evaporate before using.
Posted on Jul 02, 2009
stonephoenix
  • 563 Answers
SOURCE: black n' decker oven toaster oven broken
I work for Black & Decker customer service. Our number is 800-231-9786.
Unfortunately, our products can't be repaired. Please call the above number so that we may determine your warranty eligibility. The oven carries a one year warranty from the date of purchase.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 04, 2009
grbullets2
  • 53 Answers
SOURCE: I need to replace a dkj/1-60 timer for a toaster
You cannot find this part anywhere! I contacted the factory that makes them in China. They won't sell you one. Minimum order is 5,000 parts. I told them I was interested in a large order and asked if I could get a sample switch. They sent me 3 of them for the cost of shipping!!!!
Posted on May 20, 2010
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
I have an Oster toaster oven 6260. Looks very clean. My son got it at a garage sale. Day 1 worked fine. Day 2 plugged in doesn't go on no matter what knobs are turned. Tried different outlets. ...
It is possible that the controller switch or the trigger is absent so that the coils do not get the power from the mains circuit. it will be best if you can remove the mains plug and start tracing with a multimeter in continuity range( ohms) so that the connection is confirmed.
Once it is found that the switch does not switch on the power or has lost the connection even when it is put to the ON position then you can salvage the swittch from the older toaster to be fixed on.
If the coils have opened it can also be checked with the meter , specially since you have one top element working.
So using the inventory of the two toasters you can get one working.
Jun 17, 2011 | Toaster Ovens
When i put food in on oven setting it burns at the temp it is supposed to be at
Possibly the oven is running at a higher temperature than what you set it for. This is not uncommon for ovens. Get an oven thermometer to check what it actually runs at and then you can adjust the temperature you set it at accordingly.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 19, 2011 | Cuisinart TOB-50 Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven has No Temperature Control
    Yes they are servicable and you can do it yourself easily if you're handy. Go to smallappliance.com for parts, or just search "small appliance parts" and you will find a few places that have B&D parts. I'm pretty sure the thermostat switch is available for your oven. You will need the model # from the oven.
    Jan 24, 2010 | Black & Decker Textured TRO700 Toaster...
    The toaster oven does not toast. the oven and timer work, though
    Your selector switch may be broken if the oven works on selections other than toast.
    Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
    Rival to606 temperature control doesnt work, unit doesnt heat up
    The heating bar or element needs replacement.you can find it in electrical shop or electronic and electrical supplies in your area.
    If you find this answer helpful, kindly vote it.
    Nov 09, 2009 | Rival TO606 1500 Watts Toaster Oven with...
    Will Purchase Oven or Parts from Non-Working Oven.
    Al, your switch is likely a DKJ/1-60. As you know you can\'t find one, however there is a switch that will fix your oven. It\'s part # 05XDE5218104600 and is made for Delonghi ovens. It looks the same as the DKJ/1-60 and works the same. Get it at The Gourmet Depot website for $10 + shipping
    May 13, 2009 | Black & Decker CTO649 Toaster Oven with...
    Broiler element
    Its an on or off thing. No way to control the flow of electricity.
    The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
    Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
    Eventually the contacks will fail (unless you are one of the lucky ones).
    Good Luck
    Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
    Black & Decker CTO100 Toaster Oven with Convection Cooking Logo
    42 people viewed this question
    Top Black & Decker Toaster Ovens Experts
    Dave
    Dave
    Steve
    Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
