Question about Pool & Spa
I just filled my cal spa atlantic and the heater will not come in, the light on the top control panel is not lit. I took out the filter and let it run, turned it off and turned it back on still not heat. Any suggestions?
  • Anonymous Jan 02, 2011
    when I turn on the jets I can see flow from all the jets, and I only have one pump, 2 speeds, how do I double check to make sure I dont have an air lock? could it be the high limiter that needs to reset? if so how do you do that?
  • Anonymous Jan 03, 2011
    Problem Solver:
  • 5 Answers
Maybe a air lock ....do all the jets work do you have 1 pump or 2 pumps ...sometimes when you empty the spa and refill it gets a air pocket in the the pump/s it why you burp a baby to get the air bubble out www.dollarspa.com
Posted on Jan 02, 2011
  • dollarspa Jan 02, 2011
    lets try this take the filter out and run the the spa.. also.their is a pressure switch on the stainless steel heater with a meter you can tell if the switch is working ...it would be unlikely the high limit switch would be bad.do you have any error codes on the keypad ?
    when I turn on the jets I can see flow from all the jets, and I only have one pump, 2 speeds, how do I double check to make sure I don't have an air lock? could it be the high limiter that needs to reset? if so how do you do that?
My Great Lakes sunlighter tub will not heat - need a part number to order
check temp sensor if calling for heat check heater element
Nov 12, 2015 | Pool & Spa
Sta-rite won't turn on
possible ignitor or gas line plugged
May 29, 2012 | Sta Rite Sr333na Max E Therm Pool & Spa...
I have a cal spa ps-4-b no manual, it came with a house. I filled it up and turned on the breaker. The pumps started working but the heater light just kept flickering on and off and then just stayed off....
One of three things here.
1.the circulation pump is clogged or failing. (solution: replace or clean out)
2. the filter is old and not letting the circulation pump flow freely (solution: replace filter. to see if this is the problem. Clear the spa of debris. Turn off power. remove filter element. turn on power. see if problem persists. if this fixes it, replace the filter)
3. the heating element is bad. Typically when this happens it blows the breaker, but not always.
You can test this if you turn off power. disconnect the heater and test the heating element for resistance ratings. if you do not know how, this is something a service tech should do.
Nov 15, 2010 | Pool & Spa
What does oh mean on hot tub a cal spa
'OH' means 'over-heat'.
Basically the high-limit temperature sensor has detected a temperature far in excess of what it should be.
Check the filter(s), water flow, pump etc....
Regards,
Ian.
http://hottub.synthasite.com
Jan 26, 2010 | Coleman (5040B750) Patio Heater
Just changed the thermisor and now the heater won't turn on. 4 green lights come on the control panel: pool on,spa on, aux 1 and aux 2. the underside has 3 green led lights lit and one red for cr21.
If all you did was replace the heat sensor check to be sure that you didn't losten any other wires on the header and on the board. Often when you pull the board for inspection you can pull other wires without knowing. Also be sure your baskets and filter are clean. Good luck.
Dec 07, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Lightning Strike - Master Temp 250
I have dealt with similarly damaged boards, I can testify that while they can be repaired, the cost of labor is the most significant factor and some parts may be tough to get. I would have never undertaken it but the company which manufactured the control board (this was a sophisticated electric security gate) couldn't ship us the board in the time we could afford to wait so I repaired it. Once. The second time lightning hit it, I replaced the board and ordered the installation of a 'whole house' surge arrester.
Aug 29, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Aqualink RS6 all lights on control panel lit and won't work
I' m having the exact same problem, where the panel lights up and is non-responsive. Did you ever find a solution?
May 21, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Pool & Spa Logo
332 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
