Question about Tappan TGF363 Gas Kitchen Range
How do you relight the range pilot light?
I have a 30-3988-23
  • 4 Answers
I'd like to know, too. Thank you for your help.
Posted on Aug 26, 2008
Relighting oven pilot
They don't have a pilot light in the oven. If the oven doesn't run then either the igniter (a wavy bumpy metallic square wire looking device that glows hot) or the safely valve needs to be replaced
Oct 31, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas smell when using and not using
follow this steps and fix it. God bless you
f the pilot light on your stove goes out, natural gas may build up in your stove. If your pilot light has gone out, open the kitchen windows and doors for 15 minutes to let the gas dissipate safely then relight the pilot light. Do not relight the pilot light immediately -- striking a match could cause an explosion.
Gas Leak
  • If you can smell the sulfur-like or rotten egg smell of gas, there may be a gas leak inside or outside your home. You might also hear a hissing sound coming from the stove or another appliance or from a pipeline. Outside gas leaks may kill or stunt nearby vegetation. Signs of carbon monoxide poisoning include nausea, dizziness, fatigue and other flu-like symptoms.
f you still smell gas after relighting the pilot light, don't hesitate. Leave your home, along with the rest of your family and pets, then call your utility company or 911 from a safe location. Leave the doors and windows open behind you, especially if the odor is strong or you can hear the hissing of a gas leak. Do not turn appliances or lights on or off or use a phone in your home. Do not strike a match or use a lighter, either. Prevention
Read more: http://www.ehow.com/info_12193884_smell-gas-house-still-lingering-after-shut-off-stove.html#ixzz2aT2VTMtc
Jul 28, 2013 | Maytag MGR5752BDS Stainless Steel Gas...
Vulcan oven pilot light how to relight
Hello Lynne,
To relight the pilots,start by removing the floor of the oven,then remove the small access panel below the doors. On the main oven burner will be a small pilot burner that probably looks something like this 10_26_2011_9_29_16_pm.jpg
on the gas valve behind that small panel under the doors will be a red button,push that red button and hold it in while lighting that pilot burner...continue tohold that red button for 30 seconds,release it and the pilot should be lit.
Good luck,GENE
Oct 26, 2011 | Vulcan 60XLC Gas Kitchen Range
Pilot light has gone out we have no hot water how do we relight it the auto relight isnt working either
Hello, Thank You for using FixYa. I will be helping you today.Set the knob to pilot and push in on the knob and hold it in then push the ignitor button while still holding in the knob when it lights keep holding in the knob after a few seconds let go of the knob if the pilot stays on turn the setting to on.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Kitchen Ranges
One of my pilot lights is out on my stove range, is it safe to relight it myself?
Yes. Lift up the whole top of range from front. It pops up an inch from top and tilts back. Remove grates first. Clean off unlit orfice with brillo pad and poke the hole with a pin. light it. Gently put top down or it will blow out the pilots.
Jan 28, 2011 | Amana RanARG7302 Gas Kitchen Range
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
Pilot light is out need to relight it but do not know where it is located
The pilot is located in the bottom of the stove, you will have to remove the bottom drawer, and you will see the pilot in the back, you can relight it there, if there is no bottom drawer you will have to remove the bottom cover inside the oven and this is the location where you can relight the pilot.
Jan 07, 2010 | Hotpoint RGB745 Gas Kitchen Range
Oven pilot light too large. Can I adjust it or simplely blow it out and relight when needed?
No, do not just blow it out and relight as needed. This could be dangerous. Besides who would want to light the pilot every time you use the oven. A correctly adjusted pilot light uses a negligible amount of gas. A correctly adjusted oven pilot light should be steady and blue about 1/4" to 1/2" high. If it is yellow it is getting too little air. If there is a space between the flame and the feed tube it is getting too much air. To correct either problem turn the pilot adjustment screw slightly on the gas line near the pilot light as directed by the manufacture. Once you get it adjusted correctly leave it on.
Aug 03, 2009 | Garland H283 Gas Kitchen Range
Pilot blights wont stay lit on older model American gas range
Take a very small wire and clean out the pilot holes. Then find the pilot flame adjustment screw and re-set your pilot to 1/4 inch flame.
Mar 24, 2009 | Kitchen Ranges
Kenmore Gas Oven/Stove
the pilot light is under your surface top.Raise surface top and relight.It will be in between both burners.
Oct 26, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Tappan TGF363 Gas Kitchen Range Logo
76 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
