Question about Fuji FinePix S700 Digital Camera
Will sdhc card work in my fuji s700 camera - Fuji FinePix S700 Digital Camera
  • 747 Answers
The SDHC memory card is a newer version of the SD card and will fit in the memory card slot. However the maximum memory capacity your camera is capable of is 2gig, beyond this the card may not work. You may be able to extend this capacity with a firmware update from the Fuji site.
The SDHC memory card has a lock the same as your SD card here is a diagram to make sure the lock is in the correct position for use. Remember also to format the new card and format after each download of pictures to the computer.
Diagram
Posted on Jan 02, 2011
Zoom digital camera z650
A Fuji Finepix 2650 camera can't hold SD cards. It is made for xD picture cards only. I know there are adapters for xD camera's where you can put in a CD micro chip, but still Fuji won't give any guaranty this will work. And knowing the age go your camera, in such a adapter only SD micro cards would work and not the SDHC or SDXC micro cards.
If you do have a Kodak Z650 camera, your camera only can handle MMC and SD cards. If you bought a SDHC or a SDXC card it won't work. When there cards came out, some camera's could be upgraded with a new firmware, so they could handle the SDHC cards, but I can't find any firmware update for your camera.
There are some SD cards that go as high as 4 Gbyte, but most cards you now can buy from 2 Gbyte and up are SDHC.
Physical the cards look the same, but the addressing is different.
Jan 23, 2014 | Fuji FinePix 2650 Digital Camera
When i put insert lexor multi use into my fujifilm camera message 'protected card' with exclamation mark on screen. I am unable to take photos. Why?
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 20, 2011 | Fuji FinePix S700 Digital Camera
Will sdhc memory card work with S700?
No. The S700 works with SD and xD cards, not with SDHC cards.
Nov 20, 2010 | Fuji FinePix S700 Digital Camera
It say's "says protected card " - what should I do about it? i can look at the pictures, upload to my pc, but I can't take a picture with it.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 29, 2010 | Fuji FinePix S700 Digital Camera
I just bought a brand new scandisk 4gb card and it says that the memory is full even though i didn't take any pictures... what do i do?
The S700 uses SD cards. Your new 4GB card is actually an SDHC card. While it will fit into the slot, it will not work in the S700 (as you've discovered). You'll have to limit yourself to SD cards, 2GB and smaller.
Jun 22, 2010 | Samsung Digimax S700 Digital Camera
Im using 8gb SDHC card (scandisc) camera keeps reporting read error or write error. won't download photos, locks up etc, etc. lost many holiday photos. It is only 6 weeks old.... should Ijust use 2 mb SD -...
If all other cards work fine then you may have a faulty memory card.
Your camera should theoretically be able to handle an 8GB SDHC card (but only up to 2GB xD card) as it is an SDHC compatible camera, but I've encountered more than a few cameras in the past which were SDHC compliant but could only handle up to 4GB.
Most of these had firmware updates to enable up to 16GB SDHC but the Fuji S1000fd has no firmware update.
If you find that the SDHC card is fine after all then I'd suggest contacting Fuji for a definite say so as to whether they know of any issues with 8GB SDHC compatibility.
Oct 05, 2009 | Fuji FinePix S1000FD Digital Camera
I can't save images from my Fuji S5700 to my
Try removing the memory card and reading it through a card reader inserted into a USB port. Have you installed the program that came with the camera? I never used mine because I have other high end graphics programs and I always use a card reader instead of the cable. You WILL need the program if you want to do a firmware/BIOS update in the S700, and also the cable. The S700/5700 will only accept up to a 2gig memory card. If you want to use a 4 gig card, the camera (and also your computer) won't recognize the card until you do the update to the firmware. Available with instructions from FujifilmUSA website.
Jun 09, 2009 | Fuji FinePix S700 Digital Camera
Fuji S700
I have this camera and was able to use a "HP Invent" 4GB SDHC card. It worked fine. Although when I insert it tells me at first I have 70 minutes of video and then changes to 39 minutes. However when I recorded I was able to use all 70 minutes. Not sure if other brands or even high GB would work. I am still experimenting myself.
Nov 06, 2008 | Fuji FinePix S700 Digital Camera
"Card Not Initialized with 4GB CF memory card"
Steve, S700 and S7000 are different beasts.
S7000 is only rated for 1Gb compact flash cards. It apparently works with 2Gb ones but as I and a lot of others have discovered no matter how you tweak around sectors and clusters it won't read the thing.
This is a Fat16 limitation.
Sep 28, 2008 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S700 Digital Camera Logo
115 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
