Question about Microwave Ovens
Need manual for black & decker thermal select plus coffee maker ( TCM500) - want to know how to set timer
4 Suggested Answers
  • 8909 Answers
SOURCE: how do i set the
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 13, 2010
  • 1082 Answers
SOURCE: looking for a replacement thermal
Try here.. You'll nned model number of coffe maker.
http://buyitnow64.stores.yahoo.net/blackdecker.html
Or here.. http://www.bizrate.com/coffee-makers/black-decker-smart-brew-carafe/
Cannot find an 8 cup !!
Posted on Dec 13, 2010
  • 4 Answers
SOURCE: Looking for Black and Decker
http://useandcaremanuals.com/pdf/B220,B2250984.pdf
Posted on Mar 03, 2011
Where can I buy a replacement for the silver piece for inside this microwave?
Contact the manufacturer. General Electric and Black & Decker are joined together as one company.
Nov 14, 2015 | Microwave Ovens
I have a Black and Decker 3 cup rice cooker and have misplaced the user manual, where can I get a new one. Connie
The Use and Care Guide for the Black & Decker 3-Cup Rice Cooker, Models RC3203 and RC3303 can be found here:
http://useandcaremanuals.com/pdf/RC3203,RC33031104.pdf
Thank you for using FixYa!
Sep 17, 2011 | Microwave Ovens
My coffee maker wont turn on
Many coffee makers use neon bulbs to indicate that power is on. These do burn out after a while, but replacement is usually somewhat difficult. In this case, the coffee maker still works; you just don't have the immediate visual indication.
Many of the urn-type coffee pots have problems with the power cord breaking where it goes into the pot. To fix this, you need to remove the bottom, cut the cord where it is broken (on the outside of the pot), strip it back to match the part of the cord remaining inside the pot and crimp on new terminals of the same kind used on the original ends. The hardest part is squeezing the strain relief clamp where the cord enters the pot to remove it, and putting it back on. Study it carefully as it you remove it from the cord so you know how it works. To avoid a repeat of the same problem (and buying a new cord), be careful not twist the cord or bend it too tightly at the strain relief. NOTE: one of the wires in the power cord has a rib on the outer jacket. This is the neutral wire. Make sure it connects to the same place inside the pot as the original neutral.
Other failure points are at the power switch, or (rarely) the heater element. I've seen a programmable coffee maker with a burned-out relay (magnetic switch in a black plastic box on the circuit board). The clock and timer worked, but the heater wasn't getting any power. That part is about $5.
The easiest way to identify the problem is with an ohmmeter. Start by removing the bottom of the coffee maker (unplug it first!). Identify the heater terminals (the heater looks like a small version of the one in your oven and has either screw or slip-on terminals). Connect one of the ohmmeter test leads to each heater terminal to measure the heater resistance (typically 5 - 20 Ohms). If you have a basic (non-programmable) coffee maker, turn on the power switch and measure the resistance from each terminal to each prong on the plug. You should read either nearly zero ohms, or the heater resistance plus not more than a few tenths of an ohm. If you read open to one prong of the plug, you are on the track. Trace where the wire from that heater terminal goes. If it goes to the power switch, check the resistance of the power switch in the on position. If the reading is more than a couple of tenths of an ohm, the switch has dirty contacts, or it's broken or burned out. If you have a good connection from the heater to the power line side of the switch, but you get open from there to the hot side of the plug, the power cord is bad. Likewise, if you get an open reading from the other heater terminal to the neutral side of the plug, the cord is bad.
Programmable coffee makers have a similar troubleshooting procedure, except that you have to check for live AC voltage with the pot plugged in - this is not something to try if you aren't trained in the safe way to do this.
Sep 09, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
I am looking for the manual for Black & Decker Breadmaker B2200
Go to managemylife.com and type your model number under the "Manuals" link. Your owner's manual is available in .pdf format that can be downloaded or printed for FREE. For your convenience, here is a direct link:
http://www.managemylife.com/mmh/owner_manuals/70396/Black-Decker-Breadmaker-B220-B2250984?brand_name_search=b2200
I hope this helps you.
Mar 14, 2011 | Microwave Ovens
I have a Black 4 cup Mr Coffee with luminate lighting and time display programer so that I can have coffee brewed in the morning when I get up for work at 4:30am my problem is the coffee pot has started...
I had a black and decker coffee pot do same thing and it was brand new. here is how I fixed it.
make sure the filter seated down good. If you look at the top of the coffee pot it should open up the little valve of the coffee filter holder. also mine had a little water spout above the coffee filter that swings over the filter. make sure it is over the filter. I know my coffee pot is different, but I think the problem is the opening from filter to coffee pot is not open some how so the water is flooding over the filter and going out the sides onto counter
hope this helps
Jan 28, 2011 | Microwave Ovens
I was given a black and decker cafe central coffee machine model no bem500 but they didnt have the manual. when i turn it on it keeps coming up with a warning but does not let me know whats not working
hi Meg, when you say 'warning' which light flashes? i have the instructions. i could probably scan them and email them to you. jwas@iprimus.com.au
Nov 06, 2010 | Microwave Ovens
Will not start making coffee push start after 30 second message on screen err2 model kcm5340bo gerald larsen 1-630-323-3112
This is to do with an error in the warming plate function. You may be able to cure this error by completely unplugging the coffee maker from the mains lead and then plugging it back in and trying to brew. If this does not help I would suggest trying to contact the manufacturer to see if it is still under warranty.
Hope this helps and thank you for usinf FixYa
Aug 30, 2010 | Microwave Ovens
Microwave Ovens Logo
181 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
