Question about Dryers
Error E1 While running on timed dry will cut off after a few minutes with and Error Code E1. Started switching over to Heavy Duty cycle and normally will run thru the entire cycle. Model # 11082836100
  • 190 Answers
Dear customer,
most of the time the timers of dryers aren't faulty even though the dryer doesn't run properly in timmed mode. dryer timers have small motors on the back. The motor rotates gears and cams that open and close switch contacts that control the loads in your dryer. A load is something that does work like a motor, heater, light bulb or end of the cycle buzzer. When the timer is manufactured the amount of time each set of contacts will be closed is built in by the timer cams and i recommend yu to check the follwoing
  • Test the moisture sensor
  • Test the thermostats
  • Test the heating element
  • and finally the timer device.
hope you find this useful. thank you.
Posted on Jul 09, 2008
  • Ajith Kumar Jul 10, 2008
    Please Rate the Solution.. Thank You..
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
check the hi-limit switch on the element case or the cycling switch on the motor blower housing,they get weak and cut out too soon and dont keep element hot long enough do dry clothes properly
Apr 11, 2010 | Frigidaire Electric Dryer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer will not stay running through entire cycle or it will just stop before clothers are dry and sometimes get a E1 error message. Mostly it will just stop and clothes are not dry, times that is runs...
Most customer manuels have a code listing in the back? Have you checked to see what E1 is? It sounds like its not sensing properly. the sensor works off the the most common problem is the vent or venting. Please check and advise
Jan 02, 2008 | Kenmore Elite HE4 Electric Dryer
Lights blinking and won't clear
the solution #3 should work.. you may want to try again.... first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
Dryers Logo
360 people viewed this question
Top Dryers Experts
