Question about Danby Dehumidifier
MODEL DHH30SB21 KEEPS CLICKING IN AND OUT WON'T TAKE ANY WATER OUT , ANT SUGGESTIONS ON WHAT THE PROBLEM MAY BE
What is the drain size to run in copper for Zenith ZD300 dehumidifier. The inspector will not let us use a garden hose for drain as per you instructions. Fire hazard, we have to run a copper drain. What...
Fire Hazard? How can a rubber hose that drains water, be a fire hazard? This inspector is jerking you around. Since there are no copper fitting that will fit the connector, use a flexible stainless steel water water supply hose, that's normally used on an automatic washer. You'll wind up with 2 female ends, but that won't matter. Be sure there is a rubber washer in the end you connect to the unit's hose connection and only tighten it enough that it won't leak. If you over tighten it, it will crack or brake the plastic male connector.
Just for my own information, why is a building inspector necessary for the installation and approval of a portable dehumidifier? You can respond bu clicking on the Comment link. Thanks
Sep 19, 2011 | Whirlpool Dehumidifiers
I have an lg dehumidifier model # LHD65EBLY8. The bucket is full light keeps coming on even though it is empty. Because of this, it will not stay on and my basement keeps flooding. Do you have any...
booklover, if the the bucket is not properly installed, the unit will not turn ON. If you remove the bucket and look at the left top corner it, you will see a float device arm. It that's stuck in the UP position, jiggle the handle, so it will return to the DOWN position. In addition, that handle must make contact with the bucket removal safety switch, if not the bucket is improperly installed and the unit will not start.
Since you are using this unit in a basement, I highly recommend that you raise the unit up off the floor onto a sturdy table, counter top, etc. that can handle the weight if the unit, plus a full bucket of water. As the air temperature at floor level is colder than at chest level. The coils on your model will start to freeze at 60 degrees F and affect it efficiency, Because it is not a Low Temperature model designed for basement applications.
In addition to the dehumidifier, you would be wise to install a sump pump, if your basement floods as bad as you made it sound. Combining a sump pump with a dehumidifier will guarantee a dry basement, all the time.
Hope this helped you to troubleshoot and solve the problem.
Jul 14, 2011 | LG Dehumidifiers
Compressor won't start,can hear circuit breaker clicking out. Fan runs okay,gauges reading okay.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 06, 2011 | Fedders A7DH45B2A Dehumidifier
My matag dehumidifier Model M7dh45b2-a won't even turn on
heatman101
Jun 05, 2011 | Maytag M7DH45B2A Dehumidifier
I have an LHD6594EBL dehumidifier that won't run and it keeps saying the bucket is full but the bucket is empty, we have a hose attached and don't use the bucket,
Sue, if you haven't noticed any water draining from the hose recently, it may be that the hose connection and tubing of the unit are clogged and the drained water pressure is causing the unit to show "Bucket Full." Also, if the bucket is not properly in place, whether you use the drain hose or not, it will cause the unit to stop functioning. You know how to correct that, so I won't go into detail on that issue.
To unclog the drain, you will need an 18" long, plastic Zip Tie or something similar (NO wire coat hangers though) that will fit into the hose connection. TURN THE UNIT OFF AND UNPLUG IT. Then carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. You will have to carefully work it past this bend, until it either bottoms out or you run out of usable Zip Tie. Now, while rotating it, slowly pull it out and be prepared for some water to follow.
Hope this helped you troubleshoot and solve the problem.
Jun 01, 2011 | LG LHD659EBL Dehumidifier
My dehumidifier stopped working. It doesn,t produce ant water. Is there a common problem with this unit. It is a model HB40 By hampton bay
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Oct 25, 2008 | DeLonghi DE500 Dehumidifier
Danby  Dehumidifier Logo
51 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
