Question about Maytag Dryers
My Maytag dryer heating element does not come on-I have checked continuity on the element and it is good, though I have checked continuity on the Hi limit thermostat and do not have continuity when the unit is not turned on. Should I have continuity on that thermostat while the dryer is not on?
  • Maytag Master
  • 2,699 Answers
Yes,whatever part you are checking you have to remove at least one of the wires.if the high limit is bad most likely the dryer is filled with lint.you have to clean out the duct that the lint filter slides into,vac out the cabinet where the motor is and if the vent line is long blow it out with a leaf blower.remove the vent line from the back of the dryer make sure the outside vent is clear and blow the lint outside,just stick the leaf blower in the vent line and blow it out.if you don't do this you'll just keep blowing the high limit,it's a safety for when the dryer is running to hot.next time send the model number
Posted on Jan 02, 2011
Why is my maytag electric dryer not heating, I checked the high limit fuse for continuity, it's fine, I pulled the heating element and saw no breaks it also checked good on continuity
Several things can cause this. Improper voltage, inadequate venting, thermostats, fuses, burnt wiring, heating element, timer, or motor. Someone will have to troubleshoot all that v
Nov 18, 2017 | Maytag Dryers
Why doesn't my Maytag dryer model LDE712 heat. All things related to check have continuity.
Sometimes you have to disconnect elements of the heating system to check continuity ('element's' as in 'parts of').
Can only be 4 things
Element
high limit thermostat
high limit cut out
mainboard/switch
Feb 05, 2016 | Maytag Dryers
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Dryer wont heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 11, 2011 | Maytag Neptune MDE6700A Electric Dryer
Maytag DE7500 electric dryer blows cold air only,checked heating element.ok could it be hi temp thermostat on heating element if so how to check it to make sure
You need a voltmeter to check the continuity across the two terminals, it should be open. If there is no continuity the limit is bad..
If you found this helpful please leave a thumbs up........
Jan 01, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
MDET 235 AYW Maytag Electric dryer turns on but will not heat up. Also the timer does not shut off.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Thank you!
May 10, 2010 | Maytag Dryers
Maytag SE1000 Series 07 dryer wont heat
You need to have 220-240 or so volta ACROSS the two terminals on the element...the 125 can feed across and can be the same leg on both sides...
Check out this tip also..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 22, 2010 | Dryers
Maytag neptune electric dryer MDE5500AYQ not getting hot
You should get a diagram of your dryer *(look on the exterior back panel and under the top lid to see if they put a sticker diagram there.
Your heating element can be shorted open so no heat can be made.
You can easily check the element with continuity meter to see if it's broken. Then, check the part number from the Maytag website and price up a replacement. I would also check Ebay if the unti is older and you want to save some money on the part.
Good luck and be careful...always do your continuity checks with unit unplugged.
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag neptune dryer is not drying/ what do I do first
to check the element you need a continuity test this test insures there aren't any breaks in the heating element that you can't see. If there is continuity then you possible could have a hi limit switch (this looks like a small round button about the size of a dime, located in the housing holding your element) burnt out. If the element is burnt out there will be no continuity on the element. If there is continuity then take the hi lmit swithch out and replace it. Take the model and serial numbers to an appliance parts store for replacement. Good Luck
Dave
Jul 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer MD6
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Jun 12, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
41 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
