Question about Dryers
My dryer Bosch model number WTA3003GB/01 will not keep turning after being switched on. It works if the switch is pressed in but stops as soon as the switch is released.
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
How do you change the drive belt on a Bosch Classixx tumble dryer WTA3003GB/17?
Its a fairly simple process depending on your machine. Most Bosch machine belts are simple to replace. Here is a good resource: http://www.videojug.com/film/how-to-replace-the-belt-on-a-tumble-dryer-bosch
Dec 03, 2010 | Bosch Axxis WTA 3003 Electric Dryer
After one load, dryer stopped working. lint
With the exhaust clear, you need to be sure that air is actually moving. It could be a bound or bad exhaust blower.
Mar 28, 2010 | Bosch WTMC3500UC Gas Dryer
Does the Bosch Tumble Dryer WTA3003GB/01 have a trip reset button
YOUR DRYER HAS A FUSE AND NEEDS TO BE CHECKED. SEE IF IT IS LOCATED SOMEWHERE WHERE THE POWER CORD COMES IN AT. IT SHOULD BE CLOSE TO THE MAIN POWER COMING IN OR MAYBE EVEN IN THE CONTROL PANEL AREA.
Apr 10, 2009 | Dryers
Hi,there is no heat coming from my Bosch Tumble Dryer
USUALLY A FAULTY THERMOSTAT OR HEATER ELEMENT ASSEMBLY
Apr 09, 2009 | Bosch Dryers
Kenmore Elite gas dryer
Hello.
vegetarianGA
You said,
When I purchased my house 2 years ago, the sellers left the washer and dryer for me. They informed me of a problem with the dryer's start button not wanting to stay pressed in. They said their solutions was to use something to keep it pressed in and so I started using shipping tape for this purpose. Last night it finally stopped working - something behind the button is obviously broken (the switch). While looking for a replacement switch and an on-line service manual, I came across this site. I did order the part from Sears today and will attempt to repair the problem myself. If I cannot, I will buy a new dryer before I pay a tech $60+ to repair a 6 year-old dryer.
I did not have the model number when I called Sears but did have another number off the back of the dryer which was for the "panel control" and the number is 3979018. The sales rep did some cross-referencing and said I own model #11072932100. I was wondering if you can direct me to an on-line service manual so I will know how to replace the switch when it arrives.
Here our sponsor's site to fine what you asked me for, a service manual!
www.Manual.Pronto.com
You sound like you are right on target !
Bless You, Huuum
Please leave me a good rating before you sign off.
Thank You
Sep 05, 2008 | Kenmore Elite HE4 Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Bosch WTA 3100 Tumble Dryer ON/OFF switch
The on/off switch is combined with the door release switch in one item - part number 154145 (a little over £20) and my problem was the door interlock bit had failed. The following worked for me :
Plug out, remove top panel, and open door + look up at switch panel - you see 5 slots under the switch panel (the 2 outer ones are mostly covered by the main front panel). Start at either side and work across, using as wide-bladed a screwdriver as will fit across the slot width : put a wood block under blade as a support and lever bottom of panel towards front - each has a plastic pin behind pointing towards the rear, held by a spring clip. Each will pop clear and when all are unclipped you rotate the panel outwards from the bottom edge, taking the timer knob and its drive linkage with it. To get switch out I removed the door and the screws around the main front panel - one is hidden behind a cover plug below the access port (to gain access to bottom screws on main panel, lever the bottom panel outwards along its top edge).
Mar 09, 2008 | Dryers
Dryers Logo
139 people viewed this question
Top Dryers Experts
