Question about Minolta X-700 35mm SLR Camera
Hi, I recetly purchased an X-700. Every thing seems OK except that the shutter speed control knob seems loose. I mean it works allright but can move up and down, can tilt .... I dont know if how to describe. I do not see the firmness I expect. Thank you so much AJ
    Problem Solver:
There's a little silver ring on the inside with two little notches in it. try putting a toothpick or something small in one of these notches and turning it to the right to tighten it.
Posted on Feb 02, 2011
The phone was having crash problems so I shut it down and it would not retsrt except the lg logo
If hard reset didn't work I think it will be some problem in the hardware. best thing would be giving I to lg showroom if you have your warranty they will do it for free.
Dec 13, 2015 | LG Cell Phones
Mixer is stuck on top speed, whipped up marshmellows for 15 minutes
Referring to:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
It may be a mechanical problem and it may be a problem with the small circuit board inside the machine. In order to inspect the mechanism, remove screw #23 and then remove the cover #24. Look for a spring item #4, which will be attached to the bottom of the control plate assembly, item #28. If it is not there then the plate will not return to the slow position.
Try moving the speed control knob abd watch the action of the speed control plate. It should move freely in and out. If not then check for binding and/or loose screws.
If all the above is OK then the problem is most likely the phase control board item #30. It can be purchased online for around $15 and is fairly easy to replace.
Apr 13, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid ksm50pob no stir speed all other speeds seem ok
I don't know if it will work for you but move the speed lever from front to back a few times as fast as you can. This will polish the contacts. This is like the old fashioned TV tuners. People used to turn them slowly and then complain when they needed serviced every 6 months. Spinning the tuner knob kept the tuners working flawlessly for years.
Jan 08, 2009 | KitchenAid KSM50PR Professional Series...
Shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
Dec 28, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cold Am . I turned the left knob 45 degree . All i get is HEAT,knob moves
Hi rafis1234,
if you are handy, you can remove the small dash panel where the a/c control knobs are and then you'll access the lever mechanism and most of the time you'll find a rusty lever or someting has jammed the lever.
Cheers
Oct 28, 2008 | 2004 Nissan Sentra
Camcorders
Almost any new digital camcorder will work great, but you want to make sure it has a high speed shutter setting.  Set the shutter speed as high as possible (which means you'll need a lot of light... day light is perfect).  You're still only shooting 30 frames per second, but each shot will be sharper (less motion blur) as the shutter speed increase.  High-end cameras can go up to as much as 1/10000th of a second, but even 1/500 would be great.  Standard, default shutter speed is 1/60th.
For playback, you can use the same camera with a remote control.  Just press play, then just before the swing press pause.  Then use the frame advance button to move 1 frame at a time.  Multiple presses of the frame button will increase the speed... to slow motion.
Apr 24, 2008 | Video Cameras
Today mixer stopped while mixing.
OK, you mentioned everything except the brand. I found on some models of Sunbeam mixers that the speed governor would fail due to the control knob screw being loose.
On that particular model, the screw is behind a stick-on label in the center of the knob. Peel off the label and make sure the screw is tight.
If your mixer isn't a Sunbeam, please advise.
Mar 23, 2008 | KitchenAid KP26M1X Stand Mixer
Film Advancer loose
Hi., rotate the rewinder clockwise until the film will tightened , hold the film rotator , observe the rewinder knob moving , it means the film are engage will. then shoot for favorite angle.
Feb 18, 2008 | Pentax ME Super 35mm SLR Camera
Shutter remains open
It may be fatal as there are no parts available for the FE series. The main components that cause this problem are the FRE/ASA unit and the meter itself. The FRE is located under the rewind knob side of the top cover. It is made of glass and can be damaged by impact. The meter is under the speed dial and can also cause this type of problem. Neither is a easy repair.
Nov 25, 2007 | Nikon FE 35mm SLR Camera
What functions i can control with remote in f828?
Regarding remote control, sorry to say but it's very limited. With RM-VD1 you can only: ON/OFF Shutter release 1st and 2nd step Zoom in/out (except with F828 which has manual zoom) Rec/Stop (only with a camcorder)
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
Minolta X-700 35mm SLR Camera Logo
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
