Question about Frigidaire FullFGX831C Size Stack Gas Laundry Center
Frigidaire Laundry Center GLEH1642FS1. 2 years old. The dryer has stopped working but the washer works fine. Any suggestions on what to check out?
  • Barrett Palumbo
    Barrett Palumbo Jan 02, 2011
    stopped working how, no heat etc...
4 Suggested Answers
SOURCE: Frigidaire Laundry center blows circuit when w/d run at same time
Okay, here's the best I can do from this distance.
The combo unit is on a 30-amp, 220-volt circuit. One cord supplies both washer and dryer.
The breaker does not trip until the washer motor starts running simultaneous with the dryer drying.
My guess is that (if the combo unit is connected correclty to the one supply cord) the dryer motor runs off the 110 volt supplied by the red/white wires & the washer motor runs off the other 110 volt leg, black/white (could be vice-versa, but that's irrelevant).
The dryer heating element runs off the 220 volt supplied by the red/black wires.
There are two most likely causes (but not the only possibilities):
- The breaker is bad -- could just be oxidation on the breaker contacts in the bteaker box -- I havae seen this conditon -- small amounts of oxidation can cause the breaker to overheat and trip -- of course, the more current the load draws the hotter the breaker gets.
- One of the motors (washer or dryer) is beginnig to fail (windings beginning to short) and drawing more than rated current which is overloading the breaker.
Checking thes two theories requires some not-so-standard equipment, and some more-than-handyman expertise. And if neither of these theories pans out, the troubleshooting gets more complicated.
So, to address your original question, "Can I fix it myself, or should I hire someone?, I would say you should hire someone. This wirite-up may give them a head start.
Let me know if you have any questions.
Charlie
P.S.
A third possibility (only possible if this tripping condition ahs existed from the beginnig of the w/d installation) is that the power cord is connected to the unit such that both motors are powered by the same 110 volt leg. Not being there to assess this, I can't say how likely this is, but it's a long shot for sure.
Posted on Jun 02, 2009
SOURCE: Frigidaire Laundry Center (top load) dryer stopped working
dryer tub loose
Posted on Aug 23, 2009
  • 38 Answers
SOURCE: Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Posted on Sep 27, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
How to diagnose washer timer not turning?
Good Afternoon Friend,
I understand that the washer timer on your Frigidaire laundry center, model# GLEH1642DS, stopped turning and you want to know how you can diagnose this. Typically, this is not be a do it yourself repair, as there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose it and determine what is causing the timer button to not turn. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire GLEH1642DS Front Load Stacked...
Replaced the element on dryer and still wont heat but will spin and washer had quit working when old element went out
I understand the washer and dryer of your Frigidaire laundry center, model# FEX831CS, are both giving you troubles. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire FEX831CS Top Load Stacked...
WHY DOES MY WASHER/DRYER COMBO NOT TURN ON?
Hello Friend, thank you for your post!
Based on the symptoms you are describing, it sounds like your Frigidaire laundry center is experiencing an issue with the power supply. In this regard, I would suggest contacting an authorized service technician that will be able to assist you in the diagnosis of your appliance. Best regards! - Z
May 17, 2014 | Frigidaire FEX831CS Top Load Stacked...
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
Frigidaire FullFGX831C Size Stack Gas Laundry Center Logo
149 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
