Question about Dell Studio 1737 Laptop
Battery will not charge on labtop says (plugged in not charging 0%)
    Genius:
  • 1,098 Answers
If the battery is not charging, it is possible that the battery is already bad or the ac port is loose. If it is alreay loose, you need to resolder this from the motherboard.
Posted on Jan 02, 2011
My hp compaq turned off by itself and won't turn on now, it won't even show the charging light when the charger is plugged in
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Jun 13, 2011 | HP Compaq 6720s Notebook
Can not use my labtop without being plug in. the battery light is dem.
then theres a chance the battery is shot. this happens alot with labtops it seems and the only way to fix this would be to purchase a new battery. what happens is not all computers run on just AC power and when fully charged still use the battery. when the computer is plugged in all the time its constantly useing and charging the battery at the same time and this causes the battery to drain entirely and become useless, here is a link to get a new battery. i sugest looking around online to find better pricing but heres a start. hope this helps :)
http://www.amazon.com/Compaq-134111-B21-Laptop-Battery-Armada/dp/B00006HMZT/ref=sr_1_2?ie=UTF8&s=electronics&qid=1307488916&sr=8-2
Jun 07, 2011 | Compaq Armada M700 Notebook
How do you charge the jazzy 1103? It is on 0 on the back. Plugged it in overnight with chair on. Went from 4 to 0. Help we don't want to be stranded.
The meter on the back is an amp meter and tells you how many amps are entering the batteries when charging. Many people get confused with this and think that the needle should rise as the batteries become more charged. This is in fact incorrect and the opposite should happen. So just to sumarise, when you plug the charger in when the batteries have been used, the needle should be above 0 (maybe, 3-5 depending on how discharged the batteries are) and as the batteries become charged, the needle should gradually drop down, and should be on 0 when they are fully charged. The batteries should not be taken off charge untill the needle is on 0. Hope that has helped.
Apr 15, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Pavillion dv4 new battery only charged one time.
How long did you leave the battery for charging?
Dec 29, 2009 | HP Pavilion dv6000z Notebook
My labtop is working, but it is low on battery. I
either the power block or battery is faulty. remove battery and see if it will run directly off the power block, if not, you need a new power block.
Oct 29, 2009 | Compaq Presario CQ60-220US PC Laptop
I have a toshiba labtop but i can't seem to remember the model, but i was working on my labtop and then the charger stopped working and wouldn't charge my labtop, ive tried 4 different power outlets but my...
how old is the laptop/battery? rechargable batteries sometime with age; I'm told, over time lose their ability to hold a charge. As far as model number number, usually at the bottom side on the sticker you can find all information you need.
Aug 22, 2009 | Computers & Internet
Compaq evo n610c battery not charging
Dear All,
As per your asking that question the conclussion is there is an problem with battrey not on mother borad either problem is in Adpter connector please check out that adpter conncetor or else in the power connector in your computer iam telling you that there is an no problem in mother borad 100% suerly i tell you,
Regards
Vishwanath.K
Mar 11, 2009 | Dell Microsoft Windows XP Home Edition
Compaq Presario needed a new battery was installed labtop will not charge up!
When you install a new battery and remove a battery always make sure the laptop is completely shut off and have the power cord removed so that you avoid any possible power surge.
Batteries generally don't last much longer than a year and I have found removing the power cord or battery when it is off to be a good practice.
Before you charge a battery make sure it is run most all the way down. Recharging a battery when it is not run down can give it a memory and you may only be able to charge it up to the point you started charging it.
Anyway, if the computer won't charge a new battery then you could have a bad motherboard. To be sure try another battery.
Sep 09, 2008 | Compaq Presario Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Dell Studio 1737 Laptop Logo
389 people viewed this question
Alun Cox
