Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Stops freezing for a few days,food starts to thaw, no ice. Thn will start to freeze again
  • 1,772 Answers
Sorry to read about your problem. you can have many different problems.
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Why the heat exchanger between the freezer section and the fridge section freezes up around the second element closer to the door and makes ice on the roof of the fridge section.
If your freezer is icing up it is the defrost mechanism consisting of the timer, heating element, and defrost thermostat.
When you unplug unit everything melts and it runs fine for a few days till it freezes up again.
Usually it is the heating element that just burns out and has to be replaced.
Sep 14, 2015 | GE Refrigerators
Frozen freezer water line
Odds are your temperature is too cold in your freezer. If when you moved you just plugged in your freezer without adjusting your temperate for your new location you accidentally froze whatever water was coming into your freezer.
First you will need a cooler for whatever you have in your freezer, unless you have wonderful neighbors who will let you keep your food in their freezer for couple of days.
Take note to see what your freezer thermostat is set to. Turn off your freezer. Take out all the food. Keep the door open. This would be a great time to clean your freezer. Let the freezer thaw out for at least one day. Check the line to make sure there is no ice. Once everything has melted turn your freezer back on. Turn your freezer back on but this time set the thermostat to three or maybe 4 levels below what you had it set to before.
Finding Freezing level:
Fill an ice cube tray or small plastic cup with water. Put it in your freezer and come back in about three hours to see if has begun to freeze. If it has not begun to ice raise your thermostat to make you freezer colder by half or 1 level. Leave the ice tray or cup of water that you originally placed in the freezer but add another one. Come back in three hours to see if the water has frozen or has begun to freeze.
You want to leave the original water because you need to make sure the new water does not freeze solid as fast as the original water. If it does your freezer is too cold again.
Repeat "Finding Freezing level" until the water begins to freeze but does not freeze solid. Once your ice begins to free you can put your food back into the freezer. Wait a couple of hours more to see how much more your cubes freeze. If they are hollow or still watery in the center you should go up another half level and check on it the next day.
Once your cubes freeze solid you should be all set. If you don't get at least one tray of ice per day from your freezer you could go up another half level so your ice freezes faster.
Be careful about making your freezer colder because you might end up with the same problem you started with depending on how sesitive you thermostat is.
May 03, 2012 | Maytag MSD2578VEM (254 cu ft) Side by Side...
Why does water dispenser stop working? Seems to work fine after thawing freezer for about a day and seems to freeze up. Water line for dispenser routes through the door.
The water is door spigot can be freezing up if the ice door is stuck open. When you actuate your ice in door function you hear a solenoid CLICK. That solenoid is supposed to open the ice door flapper. If the flapper is not funtioning correctly (stuck open) then in as few as as 2 - 3 days your water in door can freeze again. If you want unit specific information we need your make and model number to better help you.
Thanks for hoosing FixYa,
Kelly
Feb 22, 2011 | GE Refrigerators
I have a Kenmore freezer top refrigerator with: Model #: 106.78202891, Serial #: EJ0320474. The problem is that the drain in the back of the freezer is freezing up and water is frozen on the bottom of...
this is a common problem that we see on a daily basis in my appliance business... over time food particles/open pkgs. etc trash will get into drain and clog it... what has happened is the drain hole located in the back bottom of freezer is stopped up and everytime the unit goes into defrost the water from the heater defrosting your coils is suppose to go down the hole since it is stopped up it is backing up into freezer and some spilling over into refrig. the whats left in freezer will freeze and continue to grow in size larger and larger...your going to have to remove panel to back of freezer inside .which is going to require removing all food and shelving/ice maker etc... unplug unit and start with a hair dryer thawing unit out. you will eventually see the hole and there will be ice in it..the water is suppose to drain all the way down to compressor area if you remove back panel on bottom you will find end of hose usually hard plastic.you want to thaw until you can run a glass of water down and see it run completely through or you will be doing it again in a few days if not it takes a good hour and a few towels but its possible. good luck
Jan 05, 2011 | Refrigerators
Ice and water not working, then freezing in refrigerator, leaking
If the water tank in the fresh food section is leaking then you will need to replace it. the freezing in the fresh food section is due to the damper door not closing when it should. at the top left of the fresh food side there is a door that controls how much cold air it gets from the Freezer side. This door on your GE is controled by a motorized door witch is controled by a controlboard witch is reading sensors in your freezer and freshfood section for tempretures.
In short your freezing problem could be any of these:
temp sensor, Motorized damper door or control board. I would check the Motorized damper door first.
Jan 07, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Ice maker freezes up
It's likely you have your freezer to cold, Try reducing the setting on that. If that doesn't work you might wanna check your freezer and make sure it's not thawing and then freezing again, you might have a problem with your fridges thermostat.
Oct 12, 2009 | LG LSC26905TT Side by Side Refrigerator
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Whirpool side by side refrigerator
The automatic defrost system is malfunctioning causing a frost build up. There are 3 components in the defrost system. A timer, a thermostat, and a heater. The most common to go is the timer. But it would have to be checked by a technician to be sure.
Jul 28, 2008 | Whirlpool Kitchen Ranges
Freezer thaws completely then freezes again
Take loock if are dirty those coils and fan on botton or some place on your freezer. Tri cleaning all. Just be carrefuly to no brake those coils ???? Unplog from outlet bifore ??? I hop you gete fix it. I'm not shur, but tri.
Jul 10, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
