Question about Frigidaire FRS20ZSG
I HAVE A FRIGIDAIRE GALLERY MODEL #FRS20ZSH. WATER IS OVERFLOWING FROM THE NEW WATER FILTER, ICE IS SLOW IN THE MAKING AND WATER IS COLLECTING ON THE BOTTOM SHELF OF THE FRIG IN THE FORM OF ICE... THX FOR THE ASSISTANCE corky@jackhammer.cc
Basti
  • 1447 Answers
SOURCE: leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Posted on Jul 14, 2008
SOURCE: have a frigidaire gallery frig
generally the filters I have changed need to be flushed with water before acutally using them because carbon can come out of the filter when first used. I don't know you specific item. Check the direction of the filter it may be installed backwards. Can you remove the filter and verify that you get water flow when the valve behind the filter is on? Just suggestions.
Posted on Dec 13, 2008
tborn6
  • 700 Answers
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Posted on Jan 30, 2009
muttandjeff
  • 359 Answers
SOURCE: water is overflowing the ice tray in my Frigidaire Gallery Series
THE WATER PRESSURE IS NOT TO HIGH ON THE HOUSE IS IT JUST ONE THING THAT CAN CAUSE THIS
Posted on Feb 24, 2009
  • 396 Answers
SOURCE: i have a frigidaire gallery series frig side by
Check for two things. Look under the refrigerator and make sure the compressor fan is turning.
Second, check inside the freezer for proper operation of the fan that moves cool air throughout the freezer and refrigerator. If this fan is working, you can probably hear it. It should be behind an access plate in the freezer (near the top). Remove the plate and look at the fan. If it's not turning, you will have to replace the fan motor.
Posted on Oct 17, 2009
I have a 16 year old Frigidaire Gallery Side by Side FRS20ZSH fridge/Freezer. We get water to the filter but not to the door dispenser or the automatic ice maker. Help please?
this could be one or two problems :
fridge door that dispenser is in is not shutting all the way any longer and the safety switch is not allowing anything to come out of dispenser , or the valves in the bottom of fridge are bad (16 years it's time to go too) these valves are not expensive and not hard to replace , just remember to turn water supply off 1st see your local or internet parts supplier to obtain them
Oct 28, 2015 | Frigidaire Refrigerators
Leaking pure source 2 ice and water filter
Hi-
Three things
Hope this help
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispensor does not get cold and ice is slow on frigidaire gallery
Look into the back of the freezer and see if there is ice beginning to build on the rear panel. If yes then you are having a defrost problem that is causing temperatures to rise, Thanks Sea Breeze
Can you find your model number?
Jul 03, 2012 | Frigidaire Refrigerators
My frigidaire gallery french door refrigerator is making ice very slowly. the water is coming out fine. It is only 4 weeks old. i got solutions from frigidaire from the valve to the water filter. Any...
The theory to making ice is temperature, water, and ice mold to function. What are the temperatures inside the freezer currently. It must be below 15 degrees to function and prefer the freezer to be at 0 degrees to product effectively. Are you ice cubes solid or hollow? If hollow you can jam the ice inside the ice maker causing slow production. Rare to have a water valve problem this young be is possible. I would look at temperatures first than cycle time to determine the next step. In a perfect world, your unit should drop ice every hour to and hour and a half.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 23, 2011 | Refrigerators
Pure Source Water Filter inside the refrig. is overflowing
most likely you have a bad filter holder the part the filter connects to,next time send the model number off of the machine so whoever helps you can look up your model and send part numbers to you.
Dec 23, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Chilled Water supplycomes out very slow. Ice maker
Its time for a new filter, the water filter will be in the upper right hand section of the freshfood section, or in the kickplate at the bottom
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water is overflowing the ice tray in my Frigidaire Gallery Series Model FRS22ZGG side-by-side
Feb 24, 2009 | Frigidaire Refrigerators
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Have a frigidaire gallery frig model plrs267zab8....can't get water, ice maker to work after inserting new filter...
Dec 13, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Refrigerators Logo
363 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
