Question about Philips 42PF9630A 42 in. Plasma Television
TV WILL NOT COME ON UNLESS THE HOUSE WAS 72 DEGREES, NOW IT WILL NOT COME ON AT ALL THE GREEN LIGHT TRIPS TO A RED BLINKING AS IT IT DID BEFORE WHEN IT WAS BELOW 72 DEGREES
  • Philips Master
  • 6,993 Answers
I don't think the temperature (degree) is the cause of the problem, I think it was just a coincidence. The TV is having a power problem, and it was giving you the sign all this while before it finally will not turn on.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 03, 2011
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony Grand Wega- Red light Blinking
I would have to say you have a bad projection lamp!! They do NOT last forever!!! About 3000 hours is normal. If this is out of warranty--about $300 in--house repair or so.
Oct 09, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture, green light keeps blinking, hear fan go on then off, blinking light changes to red
Count the blinks between the pause, Let me know or call a sony service center if your a novice at tv repair
Apr 24, 2009 | Sony KP-57WS500 57" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
I can't get my tv to turn on... nothing but blinking red light
Dont know if this will work for you or not, but my brother gave me his because of the same problem. It would power up and a green light would come on, then after 10 -15 seconds it would change to a red blinking light. I plugged a usb cable into the service port on the side and left the other end unplugged. Then plugged the tv back into the power. i took a small screwdriver and ran across the contacts in the end of the usb cable until both the red light and the green lights came on. I did this several times listening fot the clicking noises in the TV. after doing this for approx 20 seconds, i pressed the power button and the TV worked fine. 5 days now and no problems. Only thing I can think is I somehow reset the software and now it is working fine. Hope some of you can figure this out and give it a try. if the TV is just sitting, you have nothing to lose
Aug 17, 2008 | Philips 26MF231D 26 in. LCD Television
I can't get my a/c to work. I have a totaline residential thermostat P/N P374-1700. I set the thermostat to cooling only and set the temperature to 72 degrees and while the house is 75 degrees and the...
Check the drain line. Possibly tripped the float switch because the drain is clogged. Don't leave float switch out, you'll have to vacuum drain clear.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 04, 2017 | Carrier Heating & Cooling
Philips 42PF9630A 42 in. Plasma Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
