Question about Reliance Water Heaters
I have a reliance 805pv gas water heater..the pilot light is lit..I have no hot water.
  • 494 Answers
OK, make sure your ON-Pilot-OFF knob is turned to "ON" after you light the pilot. Then make sure the temperature dial is not set at vacation setting. It should be set to atleast mid range between low and high at the "A" or triangle symbol, depending on what dial you have. It will take 20-30 minutes for the water to get hot, but the burner should come on right away after it has been relit. If not, you may have to call your local gas co to look at it. Douglas
Posted on Jan 06, 2011
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
Gas water heater. Why is there no hot water?
The thermocouple and/or the gas valve may have failed
Sep 13, 2015 | Reliance Water Heaters
Pilot light not stay lit
Copy following links:
http://waterheatertimer.org/How-to-light-gas-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Reliance is made by AO Smith company, and air intake located on bottom of unit.
Make sure you have adequate incoming air and vent is working.
Remember, the pilot is located upwards from the viewing sight-glass, so it is sometimes difficult to see pilot.
Pilot flame must burn clear blue, with bits of yellow and red. Yellow flame means inadequate air supply or venting.
Gene
h
Sep 26, 2013 | Reliance Natural Gas Water Heater Control
I have a Reliance gas 501 water heater model #5 40 PORT980. Yesterday, we had no warm water. I looked and the pilot lit was lit. I turned the temperature knob to very not and it lit the
Reliance
2nd and 3rd digit of serial number is year
C05 is 2005
What color is flame? Should be clear blue.
Pilot is burning so thermocouple is good, and sitting in pilot flame.
Pilot flame should be clear blue.
Otherwise clean burner parts.
Is water at tank hot??
If burner is not turning on, the gas control thermostat is probably bad.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Otherwise more information is needed.
Sep 19, 2012 | Reliance Water Heaters
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
Reliance 606 natural gas water heater - model #640YORT - water does not stay hot. pilot has to be clicked to heat and then u can use hot water til tank empty and it will not continue to heat water.
If I understand correctly, the pilot light is not staying lit.
You light the pilot and water in the tank reaches temperature.
Once hot water is gone, then pilot light has to be lit again.
Gas pressure is good, and gas is flowing.
Thermostat is working at high end because it cuts off heating.
Vent is working because tank heats up.
Air intake is working.
Gas control thermostat might not be reading low temperature. Replace gas control valve.
Pilot tube might be dirty. Clean burner parts and combustion chamber, and air intake, and vent.
Backdraft might be blowing out pilot. Check for constant updraft by running water heater 5 minutes, and then light match under vent hood and see if smoke goes up.
Very hot air can put out pilot, especially when water heater located in attic. Add ventilation.
Improper vent might have water dripping back down into combustion chamber and putting out pilot light and rusting out the parts. Inspect for rusted parts and water.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Aug 09, 2011 | Reliance Natural Gas Water Heater Control
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
Other resources:
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
The pilot stays lit but the burner won't light.
Its an ELECTRIC hot water heater yes?
No burner or pilot then hey!!
Mar 03, 2011 | RELIANCE ELECTRIC WATER HEATER
The pilot light went out on our Reliance 501 water heater.....no hot water. We replaced the thermol coupler (sp) and re llit the pilot. We got some hot water, but only one tank ful. We then replaaced...
The paid answerers might have a specialist in your model of water heater.
As a free answerer, I specialize in providing resources that might help you for free.
When you say the gas control pieces, I assume you mean you replaced your entire gas valve with a generic dial-type gas valve.
You replaced thermocouple, but you did not replace burner assembly that includes the pilot tube.
Your other gas appliances are working fine.
You have not installed a new gas furnace with a blower that is vented up the same chimney as the water heater.
You have put your hand near the vent hood to see if there is backflow coming into the water heater when the furnace turns on.
You have removed the vent hood to give you access to the vent pipe, and you lit a match and the smoke from that match drafted upwards. You have done the lighted-match test when the furnace turns on which reveals the general condition of the venting stack.
You have checked your outdoor vent stack to make sure there is no obstruction, or the vent hood is not missing.
The burner flame on the water heater is a clear blue color with very little yellow. This shows the quality of the combustion air and reveals if amount of gas flowing to burner is restricted.
http://www.reliancewaterheaters.com/prod/gas.html
Reliance is an AO Smith company
The site doesn't have a manual for the 501
I e-mailed Reliance several weeks ago asking for a 501 manual.
They send a generic gas water heater manual with no troubleshooting
http://www.reliancewaterheaters.com/lit/om/g616.html
Link above shows a typical Reliant heater, the 616
Age of your water heater can be seen on serial number.
The two numbers following first letter are the year water heater was made.
Troubleshooting begins on pg 29
Troubleshoot flowchart begins on page 31
The new gas water heaters have the FVIR system so troubleshooting includes that information.
I don't think the 501 would have a FVIR flammable vapor prevention because it is older
The new systems have an igniter
The troubleshoot flowchart gives valuable information
Oct 29, 2010 | Reliance Water Heaters
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
Water Heaters Logo
93 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
