I PURCHSAED A 4-TO-1 A/V SWITCH CPNT410IR. ALL I GOT WAS A ROLLING PICTURE ON ALL THE TV'S I TRIED IT ON. I RETURNED THE UNIT AND THE COMPANY SENT ME ANOTHER. THE TROUBLE IS THIS NEW UNIT IS DOING THE SAME THING. A ROLLING OICTURE. DOES ANY ONE HAVE A SOLUTION?
    Brigadier General:
  • 6,966 Answers
It could either be:
1. loose or no grounding (least likely);
2. under powered (adapter should output 9VDC) (most likely).
Pls check/replace your RCA - video/audio cables or
verify that the AC power adapter is either auto-volts or set to your regions mains voltage (110 or 220 region specific).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 09, 2008
  • Louie  Role
    Louie Role Jul 09, 2008
    Or to check compatibility, try first with a standard RCA analog source.
    President:
  • 624 Answers
Check the setting on the TV and make sure you are not in the "progreesive scan" mode while using an interlaced signal. It can cause a distorted picture. Also, this switching unit is a component video switcher, it is high def and probably progressive scan signals, this is the likely cause of the rolling picture. See if the switching unit has a setting for progreesive scan and interlaced. One of the units, either the TV or the switching box is not set right.
Let me know if this helps, and do not rate it until there has been an opportunity to follow up. Thanks,
Dave
  • Dave DeGain
    Dave DeGain Jul 09, 2008
    It is also possible that the video devices that are input to the switching box are set for progressive scan and the TV is set up for interlaced.
What can be the issue when LED TV loses picture and replacement T-con board doesn't work?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 09, 2016 | Samsung Televison & Video
Rolling, Shaky picture
My best guess would be the video adapter switch you have to use to hook up the game console to the TV. If I remember correctly you have to slide a switch to either TV or game depending on whether you are watching TV or playing a game. Over time switches like that need the internal contacts cleaned. You can probably get a can of contact cleaning spray at Radio Shack. Just follow the directions on the can of contact clearer and you will probably fix your problem.
Feb 15, 2014 | Atari 2600 Console
Unit mailed for repairs....now seems to be lost, where do I go from here
Ya ever get it back??my switch went out on mine how do ya get it fixed?? It didn't last 1 winter o paid 350+ tax 4 this pos
want my money back NOW
We WE NEED CLASS ACTION LAY SUIT AGAINST THIS LIVING PURE HEATER COMPANY!!!!!
Feb 02, 2014 | As Seen On TV Living Pure Pro Series...
My picture keeps rolling
Vertical sweep problem. Check vertical output section circuits to rectify this fault.
May 05, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Frozen buttons
I think you may need to buy a new unit not on a sptial
Jun 16, 2009 | Sony DHG-HDD250 200-Hours Video Recorder
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Not getting a picture on my sharp 37' lcd 1080p tv
Not sure if you still need help but I will suggest a few things if you have not solved the problem or returned the unit.
Have you tried connecting it to one of the other HDMI inputs?
Have you also tried using the component video out from the Blu-Ray to one of the RCA inputs on the TV to see if the player is working at all? Is there another TV that you can connect it to, to test the player?
Without knowing the model of TV I am limited to solutions I can suggest. Try those and if you need more help, let me know.
Cheers
Dec 27, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Can't figure out how to get s-video conections to work
to use s-video have to switch tv/video to video input
May 03, 2008 | Durabrand DWT2704 TV
Pink screen
When the "pink screen" happens on my Polaroid FLM-1911 TV, I unplug the power cord from the back of the unit, wait 30 seconds, and replug it. This fixes the problem.
Oct 23, 2007 | Televison & Video
Picture rolling when I play DVDs
I used to have that same problem with my system. Fortunately for me, I still had the instruction booklets at the time so that helped me to figure it out. step 1: make sure there is no dvd in the dvd player before you start fixing the problem. Step 2: Press the "setup" button on the remote. Step 3: Once you have removed the dvd from the dvd player it should allow you to go to "preferences" in the setup menu. So do that. Step 4: Go to "TV TYPE" and make sure it's on NTSC. And then exit setup by pressing the setup button once again. And it should work. That's how it worked with my system at least. It seemed to switch the tv type by itself from NTSC to PAL which must be a flaw in the system. I thought I was the only one with that problem. Well, I hope that helped you at all. Have a good day.
Jan 12, 2007 | Koss KS3161 System
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
