Question about Samsung 22" TFT SYNCMASTER P2250 LCD Monitor
My new Samsung P2250 monitor sporadically dims, blinks, and turns yellow for short periods of time. How to correct?
SOURCE: Monitor color dominated by blue; Green and red colors fade away as yellow and black
probly just the chord connectin from your pc to the screen. just buy a new chord.
Posted on Jul 29, 2007
  • 333 Answers
SOURCE: Sporadic Discoloration & Distortion
Most of these monitors have a 3 year warrantly. Give them a ring and see if they will exchange it. No harm in trying!
Posted on Apr 04, 2008
Geekman
  • 32281 Answers
SOURCE: my HP Pavilion dv5000;s monitor is blinking!
This is a possible problem with the inverter that powers the back lighting panel or it could be the power adapter connector on the latop.
Wriggle the power connector which plugs into the laptop, if the LCD screen flickers then the power connector is faulty or needs resolderng (repairing).
Posted on Jan 30, 2009
  • 1684 Answers
SOURCE: Monitor just went dim.
The blinking power button indicates a short in the power supply which is then not putting out the full voltage needed to give a bright display. This is a very common problem with LCD monitors after 2-3 years of service. It is caused by heat buildup in the case causing parts called capacitors to blown out causing the power supply to short out which in turn make the power light just blink. You can repair it yourself if you can solder. We have a repair diagram posted on our web site at: www.ccl-la.com Replace the parts shown and you will be back up and running. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. Let us know if you have any other questions about the unit or the repair.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Dec 07, 2009
  • 178 Answers
SOURCE: my monitor blinks when i turn on
LED Fluorescent board to promote advertising for customer.
Posted on Sep 06, 2010
What would cause very dark blurred display all modes on Samsung P2250?
the tube lamp is degraded an needs replaced . the high voltage to the lamp might be weak corroded connection too.
consider changing the lamp out for led strip
i ordered 1 ccfl lamp many times from china for 2.50 an they are always damaged . too long for the mail.
i can order the same ccfl lamp from us for 40.
so
im going to insert led strips in place of the lamp.
its not that hard if your a tinker
Jul 25, 2014 | Samsung SyncMaster P2250 22 inch LCD...
Samsung sync masser p2250 issue
caps in power supply section are shorted out. This fools the monitor into thinking it needs to power into low mode. This is very common. Look at caps and see if they are flat on top.. if you see rounding or any fluid discharge at all, they are bad. These always go bad this way. it is on the power board only... you can take them off and read with a cap tester to see if they are the right capacitance if you wish too. You can roughly do this with a ohmeter too.. but can not see values though. Most good meters have a capacitance meter though.
May 25, 2014 | Samsung 22" TFT SYNCMASTER P2250 LCD...
Does anyone know how to disassemble a Samsung sync master p2250 22 inch? last night it smelled lime burnt Plastik and I want to take a look, but there are no screws ot smth. like that....
It uses internal plastic clips to hold the halves together. Gently pry the edges apart until you find a clip. While holding the edges apart, release the clip. You'll find about 12 of these clips hidden internally. Good luck.
Mar 19, 2014 | Samsung SyncMaster P2250 22 inch LCD...
Lately when I turn my monitor or computer off for an extended period of time, the monitor hangs in a "not on" state for a while before it turns on (The power LED slowly blinks on and off).
You will have to oen it up and inspect the inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Samsung 226BW Monitor
Damn Blinking!
You can buy a used monitor about $50.00 in the US. or You should take the monitor to an authorized repairman. IT IS NOT recommended to fiddle by banging a defective unit WHICH has HIGH voltage running through it.
Jul 26, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Mar 22, 2008 | Acer AL1912B 19" LCD Monitor
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Samsung 22" TFT SYNCMASTER P2250 LCD Monitor Logo
338 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
