Question about GE Profile DPSB619ED Electric Dryer
Our GE Profile electric dryer, model DPSE810 EG6WT, shuts off before the timed drying time is up. The display reads 00 as if it had run the scheduled time. Also, the warning buzzer does not go off. Otherwise, the dryer seems to work fine. It may be coincidence, but the light inside the drum burned out at the same time.
  • menadeau Jan 02, 2011
    Thank you. I will check out the fuse and board.
  • 4,323 Answers
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 02, 2011
Why won't my GE electric dryer shut off? My GE
The model number you submitted is not valid. Long dry times and dryer not shutting off is either an element problem, an air flow problem. Lets begin with a good model number so we can see your unit as you do...
Waiting to hear from you,Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
Apr 20, 2012 | GE Dryers
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile dryer - automatic dry never stops
ok go back to that page and
look in the
backsplash, blower section
you are looking for part
230
Oct 15, 2009 | Dryers
I have a ge profile dryer model dpsb513eboww and the sensor dry doesn't work properly. It runs 3 minutes then shuts off. The clothes are still wet. All else works fine.
You should inside the driver and on the front or back wall will be the sensor: two metal bars that send an electric current through the clothing. When the dryer detects more current goes through, it knows the clothes are still wet and keep running. If the sensor bars are broken, disconnected, or dirty, it will read no current and think you put clothes in there that were already dry. Make sure those contacts are nice and clean. Failing that, you'll need to test the sensor circuit for voltage to see what the problem is.
Sep 19, 2009 | GE DPSB513BW Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Small puddle of water from dryer?
you should check the back vent on your wall have you had any rain lately some times the strong rain will go down the back wall in the vent if broken
Jan 30, 2009 | GE WDSR2080D Top Load Washer
GE Profile Dryer - sensor problem
When I pull up the exploded view of your model, it does not show an individual moisture sensor, but is does show disconnect plug(s) for it. I can only assume that the sensor bars are an intrical part of one of the front bulkhead components. That all being said, the most common reason for your symptoms is when people use fabric softener sheets in the dryer, the sheets leave a waxy type coating on the silver sensor bars inside the drum, near the air inlet to the lint filter. If you clean those two (usually about 4 inch long x about 1/4 inch wide) metal bars off, they will be able to detect the moisture level of the clothing again, and your dryer will work on auto dry again.
Jan 24, 2009 | GE Profile DPSB620ECWW Electric Dryer
DRYER PROBLEM
my dryer shut off one day and will not start up I reset the breaker switch and no luck
Oct 06, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile DPSB619ED Electric Dryer Logo
205 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
