Question about Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE)
Hi my front USB r not working - Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE)
  • 130 Answers
Maybe due to lose connections inside the case or can happen with USB driver problems (reinstall motherboard usb driver)
Posted on Jan 02, 2011
Dear sir, i have just purchased an asus m4n68-tm mother board with amd athlon ii x2 3.0ghz processor. im facing an strange problem. i have an external 320gb western digital hard disk. the problem is the...
Hi there, It sounds like your problem is that you haven't hooked up your front USB ports to your motherboard. If you open up your computer case, you should notice some cables coming down from the front USB ports. Those cables need to be attached to USB headers on your motherboard. You should check out your motherboards manual to see where the pins for the USB headers are, and then hook up the cable. My guess would be that no USB device works via the front panel, but after hooking up these cables all devices, including your external hard drive, will. If you need more help/clarification, let me know please! Alex
Jun 03, 2011 | ASUS M4N68TM Motherboard
Usb problem dilima
strange problem, i would just get a pci usb ports card
and use that. its a quicker solution
get back to us plz
Jun 09, 2010 | Mercury P4VM800M7 Motherboard
USB did not work
1. Download and read carefully "Front panel USB Headers" at page 14 at:
PCChips P23G User's Manual
2. Verify that internal cables coming out of the front cover are not disconnected within the chassis or are correctly connected acording manual above.
May 04, 2009 | PC Chips P23G Motherboard
Location of USB Root Hub
Hi dottyo,
Generally the front USB ports on a computer are USB version 1.1, good for USB keyboard and mouse or printer.
But, almost always the USB ports on the back of the pc are USB version 2.0 which is what you are looking for. Try any ports on the back of the pc case.
Hope that helps!
Jan 03, 2009 | Dell OptiPlex 170L PC Desktop
Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Jan 01, 2009 | HP Pavilion 761n PC Desktop
My two front usb ports cant read usb hard drives
Some external USB drives require external power sources. Typically this is done either with an external power supply that connects to the drive or a second USB cable that connects to the drive and a second usb port on the pc. I have even seen one drive that comes with a Y cable. one end goes to the drive and the 2 usb plugs go to the pc.
Dec 12, 2008 | Linksys Wireless-G WRT54G Router
Front headphoes and front usb ports
maybe the wire connection of your front panel audio is not connected to your motherboard, try to have it checked by a pc
technician.
Aug 09, 2008 | ASUS Vento 3600 Dream Extreme Gaming ATX...
The 4 USB Ports in the rear stopped working. Can they easily be replaced?
hi there,
the rear USB port cannot be replaced, & glad that you still have a front USB connections into your MOBO..?
May i ask why did they suggest you to use the front USB panel..? Can you give us some info why this was happen..?
Thank you
May 27, 2008 | PC Chips M957G Motherboard
Usb port
Probably they didn't set up the front USB ports when they were wiring the computer. If you have the motherboard schematic it will show where the front USB ports connect on the board. Best have a technician take a look at it to determine and hook it up.
Hope this is of some help. Bud
May 05, 2008 | Computers & Internet
Usb not working
front USB ports are an extension of a header on the mainboard, it connects via a bunch on individual pins, if any of these pins are wrong the front USB will not work, but usually this would lock up all USB and the ones on the back will not work either, i would suggest the front USB panel was either not connected at all, or it was conected wrong, usual USB header colors of wores is BLACK, GREEN, WHITE, RED, note all mainboards are different, so the black could start from either side of the header, b sure to refer to your motherboards manual for exact pin loactions on the header
Dec 05, 2007 | Gigabyte GA-945GM-S2 (0818313003065)...
Biostar 945GZ-SE Micro Socket 775 Motherboard (945GZM775SE) Logo
49 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
