Question about Kenmore 75124 Wall/Window Air Conditioner
Blows warm air but after a few mins turns to cold air...
  • 2,133 Answers
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Posted on Jan 02, 2011
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
2007 Toyota Yaris blowing cold air for 1 min then starts blowing hot/warm air
Vacuum leak most likely, thus not operating air blend door.
Jul 01, 2015 | AC Cars & Trucks
A/c cold air stops blowing cold
Is the compressor cutting out? It could be the compressor clutch relay is going bad.
Jan 06, 2018 | 2004 Dodge Stratus
2005 jeep liberty blows cold air through the heater.
could be the thermostat if it was just stating to go bad,could also be a vacume problem not letting the door for the ac/heat close all the way for a few min.and if its really cold out like below 35,then its going to take longer to warm up,my jeep takes like around 20 min at idle to warm up.yours could be a case of over cooling in cold weather too ie(electric fans on before it warms up)that would be the thermostatic sensor.
Dec 01, 2011 | 2005 Jeep Liberty
Heating not working in landrover freelander 2001
I am having same problem with my freelander...blowing cold air. But I tried something like starting the veh and drive round for 10 mins then turn the heater speed control to 3 or 4....it started warming up and was OK until next day and I'm back with same routine...try it and see
Jan 08, 2010 | 2002 Land Rover Freelander
Heater blows cold air ,at idle and blower motor off,if you wait a couple of min and turn on blower it will blow warm air for a few mins then back to luke warm. i replaced thermostat did not help
the heater control valve is not opening all the way.
look under the hood on one on the heater hoses .
you should find a vaccum controled heater hose valve.
make sure your not low on coolant also.
also make sure none of the heater hoses are pinched off.
Nov 25, 2009 | 2000 Chrysler Sebring
Kenmore 75124 Wall/Window Air Conditioner Logo
55 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
