Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Where can I get a hard copy of manual for Bisell 7920 ProHeatr
I need to get a copy o fthe manual for the Bisselll 7920 ProHeat steam cleaner. My roller is not turning and I cannot seem to get the machine apart to even find ouow many belts it needs or where they go.
  • heehar Dec 04, 2008
    same problem but my model is a 7901. The only time the roller spins is when the machine is being pushed or pulled...is that how it is suppose to work?
  • 3 Answers
Hi Kim 9682!
Your model is included in the PDF you can get at the following link. Hope it helps! The 1st page looks empty, but just scroll down a tad. Juli ;)
newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Posted on Dec 01, 2008
    President:
  • 1,673 Answers
Try bissell.com, part number for the owner manual is 2105811. It has 2 belts, one for the pump and a cogged belt for the brush roll. Take off the belt cover on the left side and you can see the flat pump belt, if it looks ok, then turn unit over, remove the red arm retainer, has one screw, then the you can pull the arm loose and off, the cogged belt is there. If not broke, then look at the end of the pump, it is a double pulley, the inner one is for the flat belt, the outer one has a cogged pulley, the cogs may be worn down, or it has broken off, in which case you will have to replace the pump, the pulley comes only with the pump.
Posted on Sep 18, 2008
Bisell carpet cleaner lost pump prime
Hi Jay! Sorry to hear your machine has lost prime.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1065&cid=ccsocial
Feb 19, 2013 | Bissell 1699 ProHeat Clear View Upright...
Instruction manual for Little Yello Steam Cleaner
what brand name is the model BISSELLL/ SHARK/HOOVER/?
Nov 20, 2012 | Vacuums
Do thy make a replacement hose longer than 5 ft for 1425 bisselll little green proHeat
Unfortunately no. The standard length hose is all that is available. If you do need parts for this you can go to vacuumspot or nelsonvacuums both online.
Nov 01, 2010 | Bissell 1425 Little Green ProHeat Handheld...
Need manual
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rweu
Jul 24, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I need instruction on how to put fiber cleaner inside of bissell proheat vacuum. Model number 7920.
heatman101
djhdgj
Dec 20, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Soap will not dispense from Bisell Pro Heat carpet cleaners
This is a design flaw. The pump design has a problem with staying primed. Only going to another brand will you solve this problem. I recommend the Royal 7900 series extractor.
Oct 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 Problem
heatman101
fghj
Jan 08, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Instruction manual for 8910 proheat cleaner
Heres the website to download the manual. http://www.bissell.com/images/UserGuides/1699_306.pdf
Jul 19, 2007 | Bissell 8910 ProHeat Clear View Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
195 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
