Question about Hotpoint Washing Machines
Old Hotpoint won't spin tho can hear a hum (when turn dial to spin cycle)
  • douglas smith May 11, 2010
    does machine drain and does drum rotate on wash?
Clarification:
the machine neither spins nor agitates on wash cycle and apparently as a result does not drain
jungleman
Posted on Jul 14, 2008
My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
Nov 06, 2012 | Washing Machines
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
My hotpoint wm63p washing machine when in wash cycle works up until the last spin and then u hear clicking and the machine will skip the cycle and stop or sometimes just continue to the next dial cycle..i...
If you have changed the brushes are satisfied that they are fitted correctly, then it can be a couple of possibilities.
1- The motor itself is faulty.Even though it does the wash o/k it is possible the spin winding is faulty.
2- The prograqmmer is faulty.
Make sure the pump is working o/k, and that all the water has drained out, as this would stop it spinning
Dec 15, 2010 | Hotpoint Washing Machines
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint washer
Your machine has multiple issues. First, the obvious: are the water lines turned on? When you try to fill it with water, can you hear the water valve humming? Try different temperatures, too. If it lets one temp in, but not the other, you need a water valve. If it doesn't hum at all, you could have a problem with the pressure switch or the timer.
The motor humming is the issue that worries me. Try removing the belt from the motor pulley. If the motor turns now, it's a transmission problem. If it won't agitate (you'll have to satisfy the pressure switch first) or spin at all, your transmission could be locked up. I've had limited success by pulling on the belt (hard) in both directions. This has only worked once to unjam the transmission.
Mar 01, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
