Question about Telex Radio Communications
Echelen/telex headset [no model # available]quit working ,some static when cables are wiggled,about 6 yrs old,1 volume control,where can I send it for repairs? L.A.Mage CFII larrymmm@comcast.net
  • Anonymous Mar 17, 2014
    My 5 x5 Pro III 64000-102 getting static breaks in Tx/Rx every time I change my head position. Touching the line that exits the headset at its exit point causes more static but then clears the problem. This headset is over 12 years old, and probably needs servicing. Any suggestions ?
    Guru:
  • 1,833 Answers
For repair you can send it any good repairing.
Or you can contact with company customer service.
Posted on Jan 05, 2011
How do I get rid of the static sound in my 4PR908?
There causes varies from types of headset to another. In respect of a wireless headset, the static sound is caused by interference. Whereas in a cord headset, a loose wire somewhere in your headset or cord is responsible for the static sound or crackle. It might also emanate from the mic in respect of a one calling, or from the ear-piece.
The solution with a wireless headset is to move away from any device e.g computer which might have cause the static sound. Resetting the wireless headset is also a solution measure.
In the case of a cord headset; Get the cord wiggled at the plug and at the headset; and then move the mic to locate the loose connection. Where the problem occurs, loop the wire, taping it down at the point. soldering the affected wire is best than taping.
Finally, if the static sound persist;which it should not after all the treatments; check on the volume of the device. Reduction of the device volume can go a long way to bringing the longed solution. Similar problem occured with my headset;and was solved via the same recommended possibility.
Jan 30, 2015 | Wireless Gear 4PR908 Bluetooth v2.0 EDR...
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
I have been experiencing static noise/crackling from my front left and right speakers just recently. (I have a 5.1 dell system - the front center - attached to the monitor and rear speakers do not emit...
This seems like at cables have gone bad or either the connections in the speakers went bad. Its best to replace them unless you know how to disassemble and re-soder the connections.
Mar 01, 2011 | Dell WL6000 Computer Speakers
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the...
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Aug 02, 2010 | Telex Radio Communications
How do i fix the static on my bluetooth headset
Well yea but what if it doesnt have a volume control...my model is a quikcell BOLT mini auricular headset
Jul 22, 2010 | Motorola Mobility Q Bluetooth Headset...
I need the parts list, to order a broken part. Please
go to maker and search for manual by model # swampratt200~~ AAAEEE!!!!!!
Jul 21, 2009 | Telex HR-1 - Single Sided Headset with...
CS60 ear peice with heavy static when in use
This may be caused by a few things.
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too high. First, try lowering the volume on the telephone. If you still hear distortion, adjust the volume of the headset. The master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
4. Make sure the headset has been paired to the base.
Jan 20, 2009 | Plantronics CS60 Professional Headset
Headset not working
the problem might be due to the internal wiring damage.do not coil the wire much.you might have to replace it if damaged.
can also be due to the volume control, where there might be a connection loss.will wait for your further comments.good luck.
Jan 04, 2009 | Telex H-531 Headset
Telex H-551 Digital USB Headset and Audio/Microphone
Call 1-800-898-6723 x 1 (if outsidethe USA call using SKYPE. It is free to call USA toll free numbers using SKYPE.
The driver is the same for P-500. It is about 14KB in size.
I got mine today from TELEX. It is 01:11 July 29, 2008, Indian Standard Time.
Best regards,
Randy.
Dec 23, 2007 | Telex H-551 Consumer Headset
Radio Communications Logo
110 people viewed this question
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
