This problem should be removed because:
Problem with Air Conditioners
nordyne m1 series air conditioner is barely putting out cold air
our Nordyne m1 series air conditioner turns on but only blows out a little cool air. We can keep the air conditioner on for hours and it does not cool the house down. What is going on?
thanks,
suzanne
Suggested Solution (3)
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Source: Anyone have a wireing diagram for a nordyne E1EH-015HA
If you have 24 + volts between common and w or w2 when your thermostat is calling for heat, you might have a or a couple of defective heat relays or sequencers.
Source: Nordyne electric heater
check fuses and breakers first.maybe electrical,maybe mechanical
Source: nordyne condensing unit (S3D020400401) is it under warrenty
I have a Nordyne, model # e2eh017ha electric heater in my home and it has been intermittently blowing cool air instead of hot. It has now...
My blower motor doesn't blow air out the air...
My house is very hot. The blower come on but air doesn't come out the vents on the house
Anyone have a wireing diagram for a nordyne...
Anyone have a wireing diagram for a nordyne electric furnace model # E1EH-015HA
Lennox G40UH(x) series - Air not coming on
I have a Lennox G40UH(x) series furnace with a Honeywell Deluxe Programmable Thermostat CT3600A on the front end. When I put the tstat on...
we have a hvac Nordyne model P3RA-048K Everything
we have a hvac Nordyne model P3RA-048K Everything is working and there is cool air coming out of vents but the blower is tuning to slow so...
Tips for Helping suzannehawki With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
Whom to contact for AC servicing
Need preventive check up/ maintenance. Pl furnish contact no ?
E-C message
E-C error message
the green light on my fujitsu AJYA54LCLR pannels...
how do I get it to work. I turn off the main power and it works for about 5 min before flashing again
e3 error
e3 error what to do
Fix-O-Meter
312
312 people viewed this problem
- 0 people are following this problem. Be the first!
Top Air Conditioner Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
