Question about www.kilpailusivut.com iPhone4
No connection to internet kpn via thomson wireless TG789vn
Where is the WPS Button on my Thomson Speedtouch Router
Does the speedtouch 585v6 router have WPS and if so where is the ...
www.askmefast.com > Computers & Internet > Computer Networking > Router
  1. Cached
  2. Similar
Jump to The WPS button is located either at the back or top of your router.If ... - source: Trying to connect my wireless printer with the router at my new ... Router thomson speedtouch tasto wps ... Wps button speedtouch 585.
IS THERE A WPS BUTTON ON A SPEEDTOUCH ROUTER - Fixya
www.fixya.com/support/t20444391-wps_button_speedtouch_router
  1. Cached
Oct 1, 2013 - Question about Thomson Speedtouch St585 V6 Sl Wireless Modem ... do i find my password for my wireless speedtouch 585v6 router? my ...
Page 17 of the manual
https://www.cosmote.gr/fixed/documents/10280/652016/TG585_SetupUserGuide_en_v8.pdf/0878a24f-0922-408c-bd51-fff55a07f53a
Feb 02, 2017 | Thomson Computers & Internet
I want to chance port forward in Thomson TG789vn router. How do i do that. It is for playing online with XboX360
Hello there!
I guess you want to port forward for playing online games trough xbox360
Ok you need to go on webpage portforwarding.com then there select which exact router you have, specify your static ip(if you have it) or some static range ip adress, other explanations for exact router you own, are on that webpage with step by step marks and explanations. Thats about it! =)
Please rate solution! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Computers & Internet
Slow connection speed on d link wireless direct access to internet via a thomson modem is double speed why
is 54M wireless router, why u dont use only dlink Router? is Safer, and more stable than Thomson.
Jan 06, 2010 | D-Link DSL-G604T Wireless Router
I have a Thomson TG585v7 DSL wireless router. It
Check if there is any ip address added to the ethernet card of your laptop. And also check if you have enabled encyrption. If you are using DHCP then you better enable DHCP on router also..
Sep 22, 2009 | Computers & Internet
Shareaza bad downloading not more than 30 kb s my system is window  vista,  modem is thomson st 780 wl from kpn,  port 6346 , what now?how must i configurate the fire wall and modem speed...
your downloading speed depends on your connection primarily and not your modem, check what connection you have. the downloading speed is much less than the connection speed.
conncection---------downloading speed(Avg) 256kbps 30kbps 512kbps 60kbps 1mbps ~110kbps etc.
You must be having a 256 Kbps connection that is why your downloading speed is very slow.
May 06, 2009 | Computers & Internet
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
Thomson TG 585 v7 Wireless Problem
HI
The following info. might help you fixing the above problem:
For WIRELESS CONNECTION follow these Steps:
(Note: Keep the Ethernet cable plugged in unless we set up
WIRELESS)
1: Click on Home Network
2: Wlan
Click on Configure which is the 3rd last icon on the Top
Make sure that the option-Interface Enabled is ticked.
Channel selection should be ob Manuall.
Wireless channel can be 11( thats what is in my case).
Encryption is again depending on what type of sercurity you wants. I would suggest go for WPA.
After editing the above info. do not fail to note the KEY before clicking Apply
Now just enable the WIRELESS CONNECTION on your PC /
Laptop,
Pull the SSID of your router and Click connect.
It will ask for the WEP/WPA key?
Enter the key and Click connect.
Sep 11, 2008 | Computers & Internet
Setting up existing e-mail onto new pc.
wel smtp is your outgoing mail provider.
example.
email account kpn
internet account kpn
correct settings:
pop.kpn.nl
smtp.kpn.nl
email account kpn
internet acount xs4all.
this is the correct settings:
pop.kpn.nl with correct username and password
smtp.xs4all.nl
as you see you have to take the smtp address of your internet ADSL provider.
good luck.
Dec 06, 2007 | Computers & Internet
SPEEDTOUCH 576 WIRELESS MODEM driver
HERE is the manufacturer main link to download driver.
page also has manual on installing it and config modem properties.
http://www.thomson-broadband.co.uk/codepages/content3.asp?c=7&ProductID=511
Oct 16, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Facebook Apps Logo
482 people viewed this question
Top www.kilpailusivut.com Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a www.kilpailusivut.com Facebook App Expert? Answer questions, earn points and help others
