Question about Panasonic Televison & Video
My panasonic ct 32hl15n while watching it one night made some weird noises and the picture went red. you could still see the picture but it was in red. then it shut down and the power light started blinking. I turned it off and tried turning it back on and it came on for about a second or two, the color was still red, then it turned off once more and the power light started blinking again.
  • abbybay1 Jul 09, 2008
    After reading a few more sites I went back and counted the number of blinks after the tv shut down and it blinks five times then pauses.
SOURCE: Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Posted on Jul 18, 2007
SOURCE: No Picture - blinking red light.
buy a new tv
Posted on Jan 09, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 556 Answers
SOURCE: Sony KDF-50E2000 shuts down and blinks repeatedly twice.
The 2 blink error is a temperature error and the 6 blink error is a thermal fuse error. You may need to unplug the set and get you a can of canned air, take off the back lower cover and blow out all of the fans inside the set.
Posted on Oct 20, 2009
What are signs of picture tube going?
Signs of a CRT going old, are bad focussing, unnatural colours and hues of a certain colour (red, green, or blue) if you watch black/white pictures. In colour pictures, black sequences also show hue.
Jun 13, 2014 | Panasonic CT-32SL14 32" TV
Hi My wife was watching our 2002 Panasonic CT36SX12CF model t.v last night, all of a sudden there was a pop noise and the screen went black. The tv would not turn on again. Any ideas what the problem...
hey Al more than likelly it was the fuse that popped if you take the back panel off the fuse is next to the power cord and should take a 6.3 amp 125-250 volt fuse
Oct 31, 2010 | Panasonic CT-36SX12 36" TV
I have a old tv 36 inch panasonic ct-36d30 my tv
sound like yoke short problem. replace same yoke as possible . good luck!
Feb 15, 2010 | Panasonic CT-36D32 36" TV
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
TV Has no picture
http://www.bruzziforum.com/vbf/showthread.php?t=79
Panasonic probably uses the same code on your model.
Jan 11, 2008 | Panasonic CT-27HL14 27" TV
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
A lot of white noise appearing on Panasonic CT-27SL13 27 using COMCAST
You maist likely have bad ground connections inside the tuner of this TV set. Good Luck
Jun 23, 2007 | Panasonic CT-27SL13 27" TV
Horizontal lines center of Panasonic HDTV
Usually there is a capacitor in the pump up circuit and/or an IC in the vertical circuit that causes this problem. Contact Panasonic at: http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001 To find a servicer in your area. This will give you an idea of the cost of repair. Hope this helps.
Jun 02, 2007 | Panasonic CT-27HL14 27" TV
Old Panasonic TV
take your set to a tech could be having problem in your video circuit or the neck board socket need to be replace.good luck.
Mar 29, 2007 | Panasonic CT-2788YD 27" TV
Televison & Video Logo
126 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
