Question about RCA Televison & Video
TV model number is M61WH745 it keeps blowing the blube this will be the 4th one in 5 years
    Problem Solver:
  • 12 Answers
First the correct model # is M61wh74s.
there are two differnet lamps that may have been installed at the time of manufacture. you should remove the lamp access door and use the lamp part # printed on the label pasted to the inside of the access door. To use any other or a sub (which are only good for about a year) will down grade the brill of the picture and cause undue load on the ballast (supply cirucit for the lamp). Additionally if you are in an area that experiences frequent brown outs (power reduction to the home) I strongly suggest using a UPS (uninterruptable power supply) to power your DLP TV.
Posted on Feb 18, 2011
What Generation is the A1458 Model IPad?
iPad (4th generation)
  • Year: Late 2012
  • Capacity: 16, 32, 64, 128 GB
  • Model number (on the back cover):
    A1458 on the iPad (4th generation) Wi-Fi
Oct 17, 2017 | Tablets & eReaders
How can I tell how old my iPad is?
5 February 2013
iPad (4th generation) - Wikipedia
https://en.wikipedia.org/wiki/IPad_(4th_generation)On January 29, 2013, Apple announced and scheduled the launch of the 128 GB variant of 4th generation iPad. It was released on February 5, 2013. Following the announcement of the iPad Air on October 22, 2013, sales of the fourth-generation iPad were discontinued.‎History · ‎Features · ‎Hardware · ‎Reception
A1459 - Lookup Mac Specs By Serial Number, Order, Model & EMC ...
https://everymac.com/ultimate-mac-lookup/?search_keywords=A1459
Intro. October 23, 2012*, Disc. October 16, 2014**. Order, MD516LL/A*, Model, A1459 (EMC 2605*). Family, iPad 4th Gen (Wi-Fi + Cellular), ID, iPad3,5.
iPad (4th generation) - Technical Specifications - Apple Support
https://support.apple.com/kb/SP662?viewlocale=en_US Oct 14, 2016 - Model A1459*. GSM/EDGE (850, 900, 1800, 1900 MHz); UMTS/HSPA+/DC-HSDPA (850, 900, 1900, 2100 MHz); LTE (Bands 4 and 17).
Identify your iPad model - Apple Support
https://support.apple.com/en-us/HT201471 Sep 21, 2017 - A1459 on the iPad (4th generation) Wi-Fi + Cellular A1460 on the iPad (4th generation) Wi-Fi + Cellular (MM); White or black front bezel ...
Launch Date here
ipad a1459 launch date Google Search
Oct 04, 2017 | Miscellaneous
I need to know the year of a Lennox Furnace Model #C33-24B-2F
Year is typically the 3rd and 4th numbers in the serial number. "5806g13456" would be 2006
Feb 21, 2017 | Heating & Cooling
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
I have a mitsubishi the model number is wd-82837 it keep shut down after blue screen show
Ur tv"LAMP"LED light indication flashes or stay on?Ur tv projection lamp been inside this tv like a 1 1/2 or 2 years and tv been on an in used like 4 or 5 hours every day.Yes to all of this,than the tv projection lamp is the causes and it life are ending.The tv projection lamp require replacing.
Dec 09, 2010 | Mitsubishi WD-82837 82 in. HDTV DLP TV
I have a LG LCD TV 42LB1DR-UA for 4 years and I am going on my second power supply. Last one was replaced less than 1 year ago. LG says there has been no recall but I can not see paying $200 per year to...
I had mine for 2 years and the main board went out. Cost 650 dollars to fix. Its been less than a yr and a half and it went out again. Selling it on ebay for parts...
Aug 03, 2010 | LG 42LB1DRA 42 in. LCD Television
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
Televison & Video Logo
174 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
