Question about Toshiba 27AFX54 TV
Channel search on toshiba 27afx54 tv without remote control
    Top Expert:
  • Toshiba Master
  • 75,424 Answers
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Posted on Jan 02, 2011
How do I pair an ST-620 universal remote control to my Toshiba 19SLV411U?
Turn on the TV use code search on the remote control to find something that turns the TV off or causes it to change channels. Press the ENTER button or equivalent on the remote control to save the code. If a search through all codes contained in the remote control fails, you may have to try a different one.
Dec 15, 2015 | Toshiba Televison & Video
I lost my remote and need to switch the tv so I can get Directv - how can I do this without my remote
I can help you with your Toshiba TV & DirecTV remote control.
To get your TV setup so that you can view your DirecTV on it, I recommend you program your DirecTV remote to control your TV and then use the DirecTV remote to change the input of your TV to view the DirecTV programming.
You can choose between searching for the control code and
entering a code from the Toshiba TV list.
This is a list of all the Toshiba TV control codes for DIrecTV remote controls:
11524, 10154, 10156, 11256,
10060, 12006, 11945, 11936,
11935, 11918, 11704, 11656,
11635, 11369, 11356, 11343,
11325, 11306, 11156, 10845,
10832, 10822, 10650, 10149,
10148, 10036, 11971
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Code Search
DirecTV Remote Control Onscreen Setup
Apr 23, 2010 | Toshiba 24AF42 24" TV
Toshiba 2100TB tuning without the remote control
If you are sure, that there's no way to do it manually on the TV, there are only two solutions: buy a new remote control according to your TV set model (sometimes it's hard to find) or buy a universal remote control
Jan 30, 2009 | Televison & Video
How to get TV/video mode without remote
some tv do that changing the channels.
in the control panels in the tv where r the buttons for change channel there must be video button, push it and there you go.
Good Luck
Jan 12, 2009 | Toshiba 14AF44 14" TV
I lost my remote codes
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Codes
Hope this helps :)
Jun 04, 2008 | Philips Universal PH301S Remote Control
Philips remote codes
Hope this helps :)
May 25, 2008 | Televison & Video
Programing the tv
Toshiba 0154, 0156, 0060, 1356, 1656,
1704, 0650
SEARCHING FOR YOUR CODE
If your device does not respond to the remote control after trying all codes
listed for your brand, or if your brand is not listed at all, try searching for
your code.
NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and
insert the required media.
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice,
then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off
(after pressing POWER). If the device does not have a Power
key, you can substitute another function, such as digits 0 ~ 9 ,
CH, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from
its library to the selected device, starting with the most popular code
first.
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 through 5, but substitute the appropriate device key for
the device you are searching for.
here is the maual for your remote:
http://www.ofausa.com/remote_manual/URC4...
Nov 13, 2007 | One For All URC-3021 Remote Control
Toshiba 27AFX54 TV Logo
345 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
