Question about Dryers
The dryer sounds like it is functioning normally except it will not heat. I had this happen once before and the appliance repair man said it was the fuse, is this the termal fuse possibly?
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 03, 2011
1995 Kenmore Dryer heating issues
Sounds like a Heating element. Most towns have a do it you self appliance repair store. Contact them to price the part. Have you tryed vacuming th ling from the inside of the unit. Sometimes they get loaded with lint and does not heat efficiently. Hope this Helps.
Jun 21, 2013 | Dryers
My dryer wont get hot
That depends on what is wrong with it. Have you checked your fuze box? It could be something as simple as that. It sounds like the heating element though, and I am not sure how much they are to replace. You'll have to have an appliance repair man look at it to know for sure. Sorry about your problem. Good luck, hope it's a minor fix.
Good luck
Don't forget to rate these
Tanks
Jan 10, 2013 | Whirlpool WED9200SQ Electric Dryer
The washer part of the appliance functions normally, however the drying cycle spins normally but does not heat up at all, leading me to think the heating element may have stopped working? If there are any...
heatman101
Feb 17, 2011 | Dryers
Dryer not producing heat
Check thermostat/ Element....See also if has scut out @ back casing reset
Oct 08, 2009 | Dryers
We have a Whirlpool Elite Dryer. All of a sudden,
Sounds like your problem is the heating coil or the thermostat/thermistor. Chances are its the heating coil so I will deal with that.
If you plan to check/repair yourself then you need to unplug the dryer.
Remove the back of the dryer, try to locate the air tube from the blower to the drum. This is normally where the heating coil and thermostats/thermistor are located.
Once you have located the heating coil, remove the two wires and connect a continuity meter across the coil, you should read continuity across the coil...if you do not get a reading, the the coil is faulty and needs replacement.
Good luck,
I hope this helps
Oct 06, 2009 | Whirlpool Dryers
GE Electric dryer doesn't produce any heat. Before the heat totally went out, it would not self-regulate itself to stop producing heat. We would need to turn it off manually. Can you please tell us what...
I do not know the cost of repairs, but it sounds like your thermostats, and or the timer switch is faulty.
You will need to contact an appliance repair man in your area to determine the cost of repair.
I hope this helps
Oct 04, 2009 | GE Dryers
No heat
I think the problem is that your dryer element is likely bad. You would have to do some diagnosis steps to determine just what isn't working before you continue. I'm going to let you know that bypassing any control device that would allow the heat to be "ON" all the time while the dryer is running IS NOT a good idea, unless you want to have all your clothes badly scorched and/or burned up! (I've seen it happen!)
If you have a multimeter and are comfortable working aroung 220V-AC, you can fairly easily detemine if the heating element is bad or if it's something else. If you have seen a damaged wire, you should be able to get a replacement wire at most appliance parts centers or even at an electrical supply house, of the correct gauge and type.
I always look at the age of the appliance and the overall condition, before embarking on a repair. I always use the 60% rule - if the cost of the repair (or just the parts, as I do the repairs myself) exceed 60% of the cost for a new replacement appliance AND the appliance is more than 10 years old - I'll opt to get a new appliance.
If you can take some time to figure out what is defective or failed, you should be able to repair it for a relatively small cost. Dryers are pretty basic appliances and can normally be fixed fairly easily by most DIY'ers with some working knowledge of electricity and circuits. The trick is to know how to use a multimeter and be safe when you get to checking the functionality of everything once you restore power to the appliance.
Hope this helps you with your thought process as to what to do next.
Jul 30, 2009 | Dryers
No heat from dryer
Sounds like the heating element has gone bad I would call a repair man to fix. But it can be done yourself if you know how to take the housing off. Replace wire element the was the old one was on.
Jun 27, 2009 | Whirlpool LEW0050P Dryer
Dryer not drying all the way
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 08, 2008 | Estate EED4300SQ Dryer
Not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
Mar 24, 2008 | LG DLE2532W Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
