Question about Creative Labs Zen Micro MP3 Player
Zen Micro wont exit recovery mode or clean up
Ive had my Zen Micro (5gb) for a number of years and have replaced the battery within the past year. Randomly today it went into recovery mode, I did not drop the mp3 player before this. When I select Clean Up and hit Yes, it returns me to the main menu and does nothing. It has firmware v0.0.65 (I dont know if thats new or old) and rebooting does nothing. When I connect it to my PC, Organizer pops up but shows nothing on the mp3 player. When I got to Media Explorer it says its not connected (because of recovery mode?)
I really dont want to format the HD. If I do the Reset (the hole next to the power switch), will it format my mp3 player?
Any suggestions would be great.
  • 1 more comment
  • Anonymous Jul 25, 2008
    yes
  • shaun2713 Aug 03, 2008
    1. my zen vision m 30g has been stuck in reocvery mode for months..I tried using the recovery tool an downloading firmware from creatives website, but it says that the player is not detected so I cant do anything..tried reset and clean up and still nothing..please help...
  • Anonymous Jan 10, 2009
    i have de same probleme
  • 4 Answers
OK to everyone who messed up the firmware of Zen Micro and run vista, u r all idiots, including me. my zen was stuck in recovery mode and recovery menu as everyone experienced and tried to upgrade the firmware via the firmware updater that didnt work, right? ok through research and time i came to realize that what was causing the updater to fail (...please connect your media player...) is windows media player 11 (ELEVEN !!) zen update firmware will work only with windows media player 10 (TEN !!) installed. y? i dont know and i dont care anymore now that my micro is fixed up and running with the latest released firmware.
method 1:
u can find smne with xp and wmp10 (rare) install drivers and run the updater or
method 2:
u can DIY and since it is impossible to uninstall wmp11 i did the unthinkable, no no not format and install xp to use wmp10 no no.
instead i used a program called VIRTUAL MACHINE WORKSTATION 6.5 (for links keep confidential suppling ur email to me) this program will allow u to install and run several operating systems at a time regardless of your current hardware, it will run as an application in vista O/S. so i installed xp pro (on vmware 6.5) that i had handy somewhere, and then the drivers from the creative disc. then i run the firmware updater and yes it recognises my zen for the first time and loads a brand new firmware. easy as that, zen reboots and main menu appears, what a joy.
so all i used was:
vmware 6.5
xp pro (wmp10)
creative disc
firmware updater by creative
installing operating systems on vmware is very easy and doesnt require restarts etc.. u can switch through vista and xp like a window application just like that.
hope this helps, zen micro is by far the ultimate mp3 player for its sound breathtaking performance and loudness, totally worth the trouble. this is 100% fixable
Posted on Dec 16, 2008
Hey.. i tried wot u said but stil unable to get my zen micro working... can u plz provide a step by step solution.. i'l b indebted to u
Posted on Mar 21, 2010
Same as alge998!
Posted on Nov 26, 2008
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: creative zen micro doesn't show so I can transfer
1. remove all creative software from your pc (do this from start menu/settings/control panel/add or remove programs)
2. Uninstall Windows Media Player 11 and Windows Media Player 11 runtime. This will rollback the pc to an earlier version of WMP.
3. Download the latest version of the zen driver from this location:
http://us.creative.com/support/downl...ame=Windows+XP
4. Make sure the zen is not connected to the pc and install run the exe file to install the software on your pc. at some point, the install will tell you that the unit is not connected. Connect the unit to proceed. it will also notify you that you are replacing an existing software, or something to that effect. I accepted or said OK to this popup. Once the firmware is installed, my started to work fine. You can now reinstall WMP from microsoft website. Hope this works for you.
you might want to verify that your new player has the latest firmware available, as this might address the unresponsive-button issue you're having. Firmware updates are surprisingly easy - you just download the firmware file from Creative's website, plug in your player, and double-click the downloaded file. It's that easy.
Posted on Jan 18, 2008
  • 12 Answers
SOURCE: i need drivers for creative zen micro 5gb
this site should help you with your driver, go there and download it. If it doesn't works just let me know good luck to you.
http://www.nodevice.com/driver/ZEN_Micro/get34385.html
Posted on Jun 19, 2009
My brother's MP3 player is messed up. When you boot it, it automatically goes to recovery mode. Here, it tells you the firmware and gives me a couple options: Recovery Mode Creative Zen Micro...
Couple things to try.
Let the battery drain completely, then do a full charge and try again.
When turning it on, don't hold the ON slide, just slide it to ON then let it go. Holding it will send it into recovery and reset mode.
Jan 25, 2011 | Creative Labs Zen Micro MP3 Player
Credit card size zen
Hi Lil
Sounds like you have tried all the obvious. The unit may have a terminal hardware problem or an unrecoverable firmware problem. I suggest that you return the unit to a dealer and see if there support guys can produce a cure for you. I am looking for any other things that you may try. Will post any for you soon
regards
Graeme
Feb 17, 2008 | Creative Labs Zen Digital Media Player
Creative Zen Micro 5gb. Will not reboot or format. I tried replacing the drive with another 5gb drive..no luck. I even tried a 16gb Adata speedy. I've downloaded the driver from Creative site. Windows XP...
you cant increase the size of ant player so why dont you save yourself the stress if that was possible noboby would buy any hard drive again just pray it still working fine and enjoy it the way it it.
Jul 08, 2009 | Creative Labs Zen Micro MP3 Player
Creative zen
First off, download the Firmware upgrade from Creative (http://support.creative.com/downloads/welcome.aspx?nDriverType=4#type_4)
Don't run it just yet!
Now, go into the Zen Micro's Recovery Mode:
1. Take out the battery
2. Press and hold the ON/LOCK button in the ON position (far left) and put the battery back in the player.
3. The player will then switch on - wait until "Recovery Mode" appears on the screen then let go of the ON/LOCK button.
The Recovery Mode options include an option to "Reload Firmware".
Now connect your Zen Micro to your PC and run the Firmware upgrade. Your player should be recognized by the Firmware uploader. If it isn't, then then your player has other damage.
Jan 16, 2009 | Creative Labs Zen MicroPhoto MP3 Player
Creative Zen Micro MP3 5GB
May be u would have faced loose connections, for better results turn off the zen wait for 20sec and then connect it to the power and make sure u dont keep moving the zen or the cable attatched to it... Due to wear and tear loose contact becomes prone..!! Hoping for a good rating from u...!!!
Thankyou
Feb 15, 2008 | Creative Labs Zen Micro MP3 Player
Creative Zen Visions W
Replace hard drive
http://www.hardwarezone.com/articles/view.php?cid=9&id=1331
Jan 16, 2008 | Creative Labs Zen Micro MP3 Player
Zen micro photo wont load up
Try recovery tools at creative:
http://www.creative.com/products/mp3/MP3PlayerRecoveryTool/welcome.asp?region=1
Nov 29, 2007 | Creative Labs Zen Micro MP3 Player
Dropped Creative Zen Micro 5GB
needs new hard drive
· http://www.zenrepair.com/Zen/index.jsp
http://repair4player.org/disassembly_creative.html
Nov 17, 2007 | Creative Labs Zen MicroPhoto MP3 Player
Firmware not reloading
Take out the battery, press and hold the ON switch and reinsert the battery. Hold the ON switch until the recovery menu appears shortly after the Creative Logo disappears. Selection option 3, which is to reload the firmware. Keep in mind that doing so will delete everything on the player.
Oct 19, 2006 | Creative Labs Zen Micro MP3 Player
hi http://us.creative.com/support/custsup/services.asp look in "Self-help Resources" fro a driver upgrade -see if it works if not look for support good luck
Apr 19, 2006 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen Micro MP3 Player Logo
1,165 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
