Question about Maytag MFD2561HE Bottom Freezer French Door Refrigerator
Frig is sort of ticking - not constant but almost, not loud but what should I be doing about it?
  • Maytag Master
  • 8,220 Answers
The coils may need a bit of cleaning. Cobwebs and dust can cause a loss of performance. You will know it when the skin on the ice box gets warmer.
Maytag French door Service manual
Posted on Jan 02, 2011
Ticking sound is this the defrost timer on magic chef fridge
Sound like the defrost timer. Just get unit info and grab a new one and replaced. They are very simple to do
Jun 01, 2017 | Magic Chef Refrigerators
I have a ticking noise since i baought it in 09 is there a racall or is it normal
Well, um, sort of depends on two things:
1. What "it" is. Make/model/engine
2. Better description of your "ticking noise". Is it constant? How fast? Does it speed up with driving speed?
May 10, 2016 | Cars & Trucks
Refrigerator makes a loud thud every 15 minutes
compressor has a broken spring inside. only way to fix it is replace compressor. call management.
May 07, 2017 | Refrigerators
Refrig making noiise
Ask them cover deforst heater
Aug 09, 2017 | Samsung Refrigerators
Loud ticking noise coming from motor
This is probably tappet noise from the top end of the engine. However you should have it looked at quickly as these engines had a severe problem with oil sludging, even when recommended services were done.
This caused all sorts of problems, so see if you can get it fixed before the engine develops something terminal.
http://www.enginebuildermag.com/Article/66958/sludgy_saab_may_rattle_your_chain.aspx
Apr 13, 2012 | Saab 9 Cars & Trucks
Compressor does not want to start.
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
P.S. In a RARE occasion the frig may use a capacitor, and the capacitor may be bad. The only way to check is with a multimeter or replace the capacitor and see if it fixed it. This is highly unlikely and therefore not checking from the beginning.
May 29, 2010 | Kenmore 72232 / 72234 / 72239 Bottom...
The engine is an E 36 and the is a loud ticking noise coming from the right side front of the engine where the alum cover is in the front it goes away at some higher rpm's but is there on startup and idle...
Not sure of the motor. Assume you are talking about a BMW E36 (325, 358, 318 etc.) What you are probably describing is a valve tap. Sort of a ticking sound not a bang bang bang right? If this is the case you need to have your valves adjusted. Not really a job for a weekend warrior but a search on the car forums may let you decide if this is a job you want to tackle.
May 20, 2010 | Cars & Trucks
Constant loud noise when frig turns on/comes from bottom
when the compressor is running unplug the ref. and if you hear the noise coming from the compressor then
a ballance spring may be broken inside the compressor.
The compressor will run normally with a broken spring it will just be annoying when it shuts down.
Jan 16, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Constantly runs and what is the normal frig. temp?
37-39 sounds like a problem check the freeezer coil for frost buildup
May 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Maytag MFD2561HE Bottom Freezer French Door Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
