On permanent press cycle, washer fills normally, agitates for about a minute, then pumps all the water out and stops. Wash progress indicators never advance. Also at times, washer will stop and beep at 1 second intervals. The 2nd and 7th lights are on when this happens. Tried using the regular setting. It seems to be working OK.
  • aguse Jan 02, 2011
    Yes, Fisher and Paykel model GWL10U2
    Motor controller comm. error sounds like a good bet.
    Yes, lights 2
  • 1,998 Answers
Hello
ok fisher and paykell im assuming due to the lights what is the model number of your machine?as to that error code its saying display to motor controller communication error primary source display module action replace display module
secondary source motor control module action replace motor control module also says if new motor control corrects the fault replace original display module and this is in there tech sheet definetly call a technician i cant see anyone having to buy two parts to figure out which is bad once these are code for 2 and 7 light just have to double check that those were the lights that you are seeing if you have any further questions message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Posted on Jan 02, 2011
  • Rick Ead
    Rick Ead Jan 02, 2011
    Thank you could you please remember to rank how this opinion has helped if there are no further questions and have a happy new year Rick
    we try to achieve 4 thumbs up for all our chats
Agitator will not work on wash but works on pre wash and rince.
Hello, welcome to Fixya.
It sounds like you may have a broken belt based on your description,
"it starts up fine and then is silent and motionless through the entire wash cycle. this is true in normal, permanent press, and delicate cycles"
Does the timer advance if left alone after filling ?
Have you access the back panel ( removed it ) and visually inspect the washer drive system ( belt, pulley, motor ) ?
You could also have a faulty motor, although that typically manifest's in only rotating in one direction and not the other so you would see some action.
Have you tried the washer in a spin cycle ?
Let me know how far you've progressed in the diagnosis and I'll watch for your reply and assist you further if necessary.
macmarkus :)
Jun 26, 2010 | Asko 8005 Front Load Washing Machine
Washer Stops Mid-cycle
HI. this is a defective timer mechanism. it must be replaced asap, if possible. the timer is the principal initiator of the units cycles. The motor is defective at this point.
Replace this damaged timer control device asap.
Aug 20, 2009 | Kenmore 22422 Top Load Washer
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Will only work on cycle, will not agitate in the other cycles
Thanks for your question You say it works on one cycle but not the other lets sat you start a regular wash ,the washer should fill ,wash for the minutes you have set, pump out the water #spin , Stop fills & rinse stop pump out water &spin If you try a delicate cycle and it does not do what it did on regular cycle . You have a timer problem . Thanks for your question hope i helped you solve it . THE APPLIANCE DOC
Sep 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
