Question about American Standard Plumbing
Have same dual flush on all house systems. One is letting water continuously into lavatory. On examining, filling system labelled Fluid Master USA 400 series and dual flush system has no name but a number 38 8-22407000 B5. Flanges (4) on unit to attach dual flush unit to base fitting of cistern have broken off - so preventing seal and allowing water to continually leak into lavatory pan. Flushing unit also firmly attached to press-button component and therefore ceramic cistern top cover . Have not tried to fix it yet but need to know full spec to order and whether new unit will have full instructions on how to detach unit from cistern top and push button component OR can you tell me how best to do it?
leecom72
  • 4806 Answers
SOURCE: Water leaking from top of RO system.
is there an internal float that is stuck allowing overflow?
Posted on Nov 18, 2008
  • 2692 Answers
SOURCE: The faucet leak is from the top gasket around the control handle.
Yes, Grone will give provide a daagram and parts list.    All you need to know is the model number. The beasst source for parts is the manufactor. Can you match it up? Is it single lever or two handles? Can you go to a grone dealer and look it up in their model book? THey can also provide the rebuild parts.
Posted on Apr 25, 2009
  • 3 Answers
SOURCE: Pegasus Push Button Drain leaks when you push the button
REMOVE THE LOCKNUT AND CHECK FOR A CRACK OR PIN HOLE IN DOWN DRIAN USE A FLASH LITE IN DRIAN TURN OFF ALL LITES TO CHECK PUT LITE IN DRAIN AND CK FOR LITE IN THE DRIAN PIPE
Posted on May 07, 2009
  • 297 Answers
SOURCE: My whip dual flush toilet leaks around the flapper
the flush neck must be pitted or someting, the part that the flapper sits on that needs to be replaced.
Posted on Jul 14, 2009
  • 297 Answers
SOURCE: Replacing the ceramic valve in the handle, how do you remove it?
it has a screw down cap on top of the valve.counterclock wise.then pull straight up on valve. if you twist the supply line while doing this disconnect the line first then work on valve.
Posted on Jul 15, 2009
What do I do if someone of lower than normal intelligence not me put a little ATF fluid in the Brake Master cylinder?
Completely drain the brake system,
refill with new fluid and purge ,
drain again
refill again and purge
Jul 07, 2017 | Cars & Trucks
HOW TO FLUSH AND RENEW COOLANT?
if the thermostat is in the head at the top radiator hose , remove it an fill the cooling system until the water is at that point --refit the thermostat and continue filling
make sure that the heater is turned on so that any air is moved out of the system
May 30, 2016 | Cars & Trucks
My troopy over heats with the air con on when I'm on the high way or going up a hill its a 1 hz 1994 model what could be the problem
Hi Tony, cooking system low on fluid, circulation could be restricted (radiator) or thermostat going south. good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 03, 2015 | Cars & Trucks
I have a uberhaus dual flush toilet. I turned off the water supply in the house to work on a sink and when I turned it back on the toilet won't fill anymore. If I fill the tank or the bowl it will flush...
You will have to disassemble the fill valve and clean it. When you shut the water off and on to work on the sink it dislodged dirt and scale in the water piping which clogged the toilet fill valve. Check your lavatory sink areators too they may also be partially plugged. Hope this helps.
Bob
Jun 09, 2014 | Home
Jacuzzi toilet
After flush the system must close the hole which lets water into the toilet. If it does not close after flush, it is continuously letting the water thru. Check if it closes after flush and allows tank to fill.
Jul 10, 2013 | Home
What is proper method for flushing the radiator and engine in a 1999 Pontiac Montana?
1: Drain coolant system
2: Purchase coolant flush, making sure you have the proper amount for your size of coolant system
3: Pour coolant flush into your radiator, filling the rest with water
4: On the coolant flush bottle it will tell you how long to run your vehicle
5: Once done running, let cool enough to open radiator cap, and drain system COMPLETELY by first draining out of pep **** on radiator, then taking one side of the hoses off the radiator and draining those
6: Put hoses back on and fill system with coolant. When the fluid gets to the top of the fill port on radiator, start vehicle and let run, allowing air to escape the system, and fill as necessary
Oct 27, 2012 | 1999 Pontiac Montana
Where is the bleed bolt for the coolant system of a 98 ford windstar. I am trying to bleed my collant system because I the hea is very spuratic. I have put the van on an incline and run it with the...
There's a bleed screw located at the bottom of the radiator. Open screw let fluid run out of radiator. Fill radiator with water run vehicle. Repeat above steps until fluid is clear. Use a coolant system flush. Refill system with appropriate amount of coolant and water.
Oct 18, 2017 | 1998 Ford Windstar
Aquia II Dual Flush Toilet: toilet after flush removes to much water from bowl...
Adjust the float on the Fluid-master a little higher if possible. This should allow more water to enter the bowl after the flush.
May 16, 2010 | Toto Aquia II Dual Flush Toilet
Toilet acts like it's getting pluged up as soon as you flush .
use a two gallon buck to flush your toilet - you pour the two gallons directly into the toilet bowl if it flushes fine you need to replace the flush valve, as it is not letting enough water through to properly flush the commode. either rebuild the flush system in the tank or install a fluid master and have a good nights sleep knowing that in the morning you will not leave a suprise for someone else in the family.
Mar 15, 2010 | Gerber Blades Gerber Ultra Flush 10" White...
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Plumbing Logo
702 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
