Question about Honeywell Cool Mist HCM890 Humidifier
Humidifier runs but water level does not go down filter completly dry.
JohnSc
  • 21 Answers
SOURCE: runs, but no humidity
These things have a "sponge" appearing part that is located below the tank. Be sure to totally soak that part in water before trying to use the unit. I had one of these about 3 years ago, and the same thing happened to me. I believe the "sponge", which is really a filter, actually wicks the water into the section of the humidifier that sends water vapor out of the top. You must completely soak it to "Prime" the system, so to speak. That is what worked for me.
Posted on Feb 11, 2008
  • 123 Answers
SOURCE: Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
Posted on Apr 18, 2008
billyvangogh
  • 108 Answers
SOURCE: My honeywell humidifier attachment on my furnace
Humidifiers usually are wired up to ONLY come on when the Heat is on and the fan running....anyother time you check it it will not be powered or wet...turn your heat on , wait till the fan comes on...then turn up your humidistat you should hear a click if its a flow through type and water should start flowing from the top...or if its tyhe drum style with the sponge...you should see it then turning...if it doesnt turn the pad/spindle may not be installed properly...if only fits one way
Posted on Oct 25, 2009
jmgldsmth
  • 1906 Answers
SOURCE: Have a Honeywell Humidifier that is attached to my
your water inlit float is blocked or, out of adjustment
Posted on Jan 17, 2010
  • 4736 Answers
SOURCE: The air in my house is very dry but the humidifier
The humidity level setting may be set to low. 40% is right for most home environments. However, you made need to set yours at 50%.
Posted on Feb 23, 2011
Wont run in unit lift out and lift level control works fine put it back in unit [ very tight fit] lift level control wont work
Hello.
The GE humidifier adds a continuous stream of cool mist intothe air, giving moisture to dry air due to cold weather or dry climate or tohelp those who desire additional moisture because of respiratory problems orallergies. Sold online and in many department or home retail stores, thehumidifier requires regular cleaning and maintenance for proper functioning andto help keep mineral scale or bacteria from growing in the humidifier. ·1 Connect the power cord on the GE humidifier firmly to a power outlet if thehumidifier is not working. Replace or reset the circuit breaker as necessary.Turn the power switch to "On" if there is power but the unit is notoperating. · 2 Fill thewater tank to the "Fill" mark if the mist output is low or notpresent. Wait 15 minutes after filling the tank and before starting thehumidifier to allow the wick filter to absorb the water for proper function.Turn the humidistat knob to a higher setting for higher output. · 3 Check the capon the water tank and close the cap firmly. Check the rubber tank cap ring onthe cap and reseat firmly to help provide a better seal. · 4 Replace thewick filter with a new wick filter, available through General Electric, if thewick filter inside the base turns brown. Replacement parts may be ordered bycalling 877-207-0923. · 5 Clean thewater tank with vinegar and a soft brush if the water begins to get cloudy.Rinse well before refilling with water. Use cold water in the tank, as warm orhot water may make the water appear cloudy. · 6 Loosen thetank cap slightly if the humidifier cycles on and off unexpectedly. Turn theknob to a higher or lower setting. Thanks.
Sep 09, 2011 | Sunbeam Humidifiers
House is dry though it's quite cold outside and furnace is running. Aprilaire is turned up to 35 (I have a dial, not a digital panel). the water panel is completely dry (should it be?)
unless the humidty in your home is higher then 35%. if it is then the humidifier would not run. try turning it up higher and see if it comes on. Do you hear a click in the humidistat? as you turn up the dail when you hear the click is when the humidifier should come on. Also remember your furnace must be running for the humidifier to come on. if you hear the click and the humidifier fan comes on but no water, you may have a clogged inline filter located in the solinoid valve or a bad soliniod. all parts for your humifier can be purchased from www.aprilaire.com
Feb 05, 2010 | Aprilaire 700 Humidifier
Not using water, filters are dry, doesn't humidify air.
Check your water supply. Make sure the valves are open and/or not blocked. You could have a blocked orifice in the water line by the solenoid valve. Check to see if your humidistat is set high enough. When you replace the water panel could you have accidentally disconnected a wire. Is the door on good. Some humidifiers must have the door closed properly to maintain a proper low voltage connection.
Good luck
Mar 14, 2009 | Kenmore Humidifiers
Hunter Humidifier #33222
From The Hunter Manual
1. Turn the humidifier ‘OFF’ and unplug the unit.
2. Lift the main housing and remove the water dispersion tray and the PermaWick™ Filters. The motor is attached to the main housing. Do not place the motor near water. Do not use a wet towel on the motor or motor housing as electrical shock may occur.
3. The PermaWick™ Filter should be cleaned in a vinegar and water solution to remove any mineral buildup. Place in a solution of one (1) gallon of water and eight (8) ounces of undiluted white vinegar. Allow the filter to soak for 20 minutes.
4. After soaking, rinse it several times with clean water. Place the PermaWick™ Filter in a location where it can drip dry while you clean the other parts of your humidifier.
5. Remove the water tank from the base and empty any water that is left in the tank. Soak the base in a mixture of one (1) gallon of water and eight (8) ounces of vinegar for 20 minutes.
6. After soaking, wipe the base with a soft cloth or sponge to remove any mineral build up. Rinse with clean water several times. If you are planning on storing the humidifier, be sure the base is completely dry.
7. Fill the water tank with one (1) gallon of water and eight ounces of undiluted white vinegar. Replace the tank cap and shake the tank vigorously until all interior surfaces of the tank have been exposed to the water/vinegar mixture.
8. Empty the tank of the water/vinegar mixture. Rinse it several times with clean water and then replace the tank cap. If you are planning on storing the humidifier, dry it inside and out, leaving the cap off to allow the tank to completely dry. Continue to clean the other parts of your humidifier.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes.
Rinse well and reinstall the water diffuser cap. Do not expose motor or other electrical components to water.
10. Wipe the surfaces of the main housing with a soft cloth.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOUR HUMIDIFIER to continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Jan 16, 2009 | Hunter CareFree Plus 33222 Humidifier
How do I clean Hunter Humidifier #33222 ?
From The Hunter 3322 manual.
9. Remove the water diffuser cap by squeezing the two tabs as shown in Figure 3. Rinse the cap in clean water to remove any debris. If the cap contains hard water residue, soak it in a mixture of one (1) quart of water and two (2) ounces of vinegar for 20 minutes. 41553-01 01/03/2008 6 © 2008 Hunter Fan Company
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location
Not adding moisture to the air
Have you cleaned the unit lately? The following is from the owners manual.
Jan 04, 2009 | Hunter CareFree Plus 33222 Humidifier
I need to know how to clean my filters on Hunter Humidifier Model # 33222. I have misplaced my instructions.
The instruction manual suggests using the water vinegar solution.
The following is from the manual.
11. Once all the parts are clean, reassemble the humidifier, and follow the USING YOURHUMIDIFIERto continue use. If you are storing the humidifier, make sure the parts are completely dry, reassemble, and store in a dry location.
Dec 18, 2008 | Hunter CareFree Plus 33222 Humidifier
Runs, but no humidity
Feb 11, 2008 | Honeywell HCM525 Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Honeywell Cool Mist HCM890 Humidifier Logo
777 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
