Question about Polaris Pool & Spa
My booster pump is not working. There is voltage coming out of the switch and voltage at the motor. The shaft is free and rotates smoothly. Can I change the capacitor? and if so how do I do it safely, they can hold quite a charge for a long time. thanks
    President:
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
Start with the capacitor. Use a digital multi-meter (DMM), preferably with a capacitor setting, or an analog meter set for Ohms. With an analog, you should see the needle deflect as if testing a closed circuit then it will slowly drop to 0 if the capacitor is good. If it doesn't move or moves and stays to the side showing a closed circuit the capacitor is bad. If you notice a burn hole near the terminals on the end of the capacitor do not bother to test it. If you do not have access to a meter you can try grounding the posts together with a screwdriver to see if they arc although It is not a very reliable test method. Be sure you are holding on to an insulated handle for the tool you use to short the terminals together or you can get a good poke.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage. If you wish to continue to try to repair it yourself please comment with any questions you have as you work thru the pump and motor.
If this answer does not fix your problem, please comment with additional details or contact me thru our site at www.arrowpools.net prior to rating the answer; I'll do what I can to help. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 02, 2011
Brand new motor replaced old pb4. After installation it just hums and does not pump. Before installation it works fine without water going through? Any body know what is wrong?
Double check the wiring installation. One wire wrong will stop it. Don't let it hum! Compare old motor to new, are they the same voltage? Can you rotate the motor by hand? It should be free.
Oct 26, 2013 | Polaris Pb460 Polaris Booster Pump...
I have an aqua flow master 3.8 hp xp2 pump in my hot tub, it sounds like it is receiving power as it is clicking on but it will not start. have i fried the motor? the shaft turns ok but nothing is...
Many of these pump motors have a capacitor and start & run windings. I had a pump motor a week ago that was free to rotate, but only hummed. I looked inside the back end, everything looked good, I bought a capacitor online for $7 + $15 shipping, installed it and it worked. The capacitor will have voltage & rating on the side.
BE CAREFUL, CAPACITORS KEEP VOLTAGE EVEN WHEN NOT PLUGGED IN. If you don't know how to handle them, take the motor to a local motor repair shop.
Gary
Aug 02, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Polaris booster pump: Voltage okay shaft okay turns no leaks capacitor okay, and new still humms what is the problem?
Assuming the capacitor is truly ok then either the starting switch that controls the capacitor is the issue or the winding itself. The switch may be worth fixing assuming the rest of the motor is sound. It may just need the contact arm(s) bent back into position. If it is burned up do not bother going further. The likelihood of further motor damage already or in the immediate future make it uneconomical to repair. If it is the winding already, replace the motor.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 23, 2011 | Polaris Pb4 - 60 Booster Pump
The booster pump on my legend 11 pool cleaner won't start. I can hear it activate the capacitor. I replaced the capacitor this weekend with the same result I can reach in the pump housing and rotate...
The capacitor should not be making any noise. If you hear a click it is most likely a relay. Are you hearing this inside the motor, or in a control panel or timer box? If it's inside the motor, and the shaft spins free, then it's quite possible the motor windings are bad. You can check these to some degree by yourself, by disconnecting the power (must physically remove the wires from the screws), then check with an ohm meter. (depending on your motor and if it's more than one speed you may have multiple sets of windings, for start, run, and different speeds. If the above is not clear to you, I would recommend taking the motor to a pool shop that rebuilds and test motors. Look for a shop that specializes in pool pump repair, but some supply shops do it as well. They should test it for free and advise you from there. Good Luck!
Sep 20, 2010 | Pentair Legend II Pool Cleaner
I have a Polaris PB4 booster pump, installed late July 2006, vacuum was running for an hour tonight but I noticed it wasn't moving across bottom of pool normally--wheel was skipping. I shut things down...
The click is the internal thermal overload. Since the pump wouldn't start it overloaded and opened the circuit. Either there is something jammed in the impelller locking the pump up or you have a motor problem. IF it a capacitor start motor, you could have a bad capacitor. Or if it has a starting switch it may not be operating. Start off and be sure the motor turns freely. If you replace capacitor be sure it is same voltage and MFD as the old.Check all wiring connections.
Aug 18, 2010 | Polaris Pb4 - 60 Booster Pump
Hayward flo pump motor repair
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
How do you take off motor
1. Disconnect the booster pumpset from the power
supply.
2. Take the pump frontcase off by taking the bolts
holding it.
3. Take the pump impeller from the shaft. This is
either bolted or screwed to the shaft that is
actually an extension of the motor.
4. Carefully take the mechanical seal off from the
shaft.
5. Unbolt the pump backcase, from the motor,
6. Now you have the motor separated from the pump.
Nov 16, 2009 | Grundfos JPS4 1 HP Pressure Booster Pump
My wet end is leaking from the backside.
I have a executive 56 frame 4 hp water way motor - PF-40-2N22C. Wet end was leaking at shaft, had it fixed and now the motor won't rotate at all. shaft is free it just hums. Checked supply voltage and the voltage at the connector. All is ok, what do i do now.
May 21, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
My polaris booster pump will not come on. when i turn it on the motor makes a humming noise but wont start
Does it have a century motor? If so, remove the shaft cover plate at the rear and try rotating the shaft with a very thick slotted screwdriver or substitute until it turns fairly easily. Often some mild oxide develops around components that just needs to be disturbed.
Apr 12, 2009 | Polaris Pb460 Polaris Booster Pump...
Impeller loose on pump motor shaft
The bore in the impeller is spun out. Mix some JB Weld and apply a liberal amount to the bore of the impeller, install it back on the motor shaft and rotate the shaft a 1/2 turn to distribute the weld before cure. Originally the impeller was a press fit. Don't allow food to get sucked into the pump, lock down and damage to the impeller will occur
May 22, 2017 | Amana 24 in. ADB2200AW Built-In Dishwasher
Pool & Spa Logo
311 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
