Question about E46 Anti-theft Alarm System 1999-2006 3ser Bnib
Bmw 323i mod. 2000 , The alarm flickers and works but no sound heard at any time. is there a switch or a remote command to turn on the sound of the alarm?
    Genius:
  • 1,098 Answers
Hi
Hold the button on the remote down for about 8 seconds, this should give you the audiable alrm, if not then you may have a fault with the hood/bonnet switch, these often jam up and so the car thinks someone is trying to steal it very common fault on the 3 series. sounds silly but take a look at the pin switch on the slam panel push it in out etc see how it feels.
Get back to me if that does not cure it.
Regards
Dan
Posted on Jan 02, 2011
Unlock drivers side door when key won't work
All BNW's have remote key openers built into key, so what doesn't work, the manual lock, or the remote key, or both. When you say you don't have keyless entry, on a BMW the remote is the key.
CeraCoat-NanoTech.com
Jan 28, 2015 | 2000 BMW 323i
I have a 2000 BMW 323i that will not start we get a clicking sound but does turn over everything works will not turn over
have you tried to jump start it direct to the battery and not at the jump points under the hood
Aug 17, 2012 | 2003 BMW 325
My 2000 hyundai tiburon alarmed itself and the alarm is sounding. I have no remote control that works.
Put key in ignition, turn all the way forward, but not trying to start. Let alarm cycle 2 times, when it stops the 2nd time, remove key and alarm should be disarmed. This will only work if it is a factory alarm.
Jan 20, 2018 | Hyundai Motor 2000 Tiburon
2000 bmw 323i remote door locks do not work and alarm system not functioning
Have you replaced the battery in the remote? If you haven't then make sure you get the battery first and perform a quick swap out so you don't lose the keyfob's memory.
Dec 29, 2010 | 1999 BMW 323 Series
2000 BMW my remote is not working. is that a battery type key? 2000 BMW 323I
yes it is you may need new battery on the remote take it to the auto part and the check you're batteries and remote signal.they have the tools to check remotes signal
Aug 30, 2010 | BMW 323 Cars & Trucks
Need a fuse box diagram for a 2000 bmw 323i
air conditioning and climate control does not work on my bmw 323i 1999 after my wife ran into a pothole.
any suggestions? do you know which fuse number operates these systems?
Jun 03, 2010 | 2000 BMW 3 Series
I can not start my BMW 2000 323i with the key. The engine will not even attempt to turn over. Everything else works fine. One key failed on Sunday and began using a different key and that worked until...
Check the battery cables a loose connection can cause this. It they are tight check ignition switch.
With 2 key failures in such a short time it may be security ignition interrupt issue
Jul 16, 2009 | 2000 BMW 3 Series
2000 bmw 323i auto trans wont go in reverse. i just had the front and rear brake pads and rotors changed. the ABS light is on as well even after the change.
ive heard people say that on a auto transmission on a BMW that if it wont go into reverse there might be something wrong with the transmission... just a thought, i might be wrong
Jul 09, 2009 | 1999 BMW 323 Series
E46 Anti-theft Alarm System 1999-2006 3ser Bnib Logo
739 people viewed this question
Top BMW Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
greg benton
Are you a BMW Vehicle Part and Accessory Expert? Answer questions, earn points and help others
