Question about HP OfficeJet 7310 All-In-One InkJet Printer
I keep getting message: "Remove and check ink
    Scholar:
  • 111 Answers
If you have already checked it by taking out and inserting it back then try this
Do it only if you have connected the printer by USB
1. Unplug the power cord
2. Press and # and 6 at the same time
3. While holding them plugin the power cord, you will see a message
SEMI FULL RESET on the screen
Release the buttons and let the Printer do what ever its doing
Posted on Jan 02, 2011
I need to make the ink carriage move over so I can replace the ink cartridges inmy workforce 840. Online here it says "hit theink button" what the heck does that mean? Where is this ink button?...
this is out of the manual
Replacing Ink Cartridges
Make sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the
ink remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If you're replacing a cartridge before you see a message on the LCD screen,
press Setup, select Maintenance, then select Ink Cartridge Replacement.
3. Raise the scanner.
4. Open the cartridge cover. Then squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets
into your eyes, flush them immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package, shake
it gently four or five times. Then remove it from
the package.
6. Remove the yellow tape from the bottom of the
ink cartridge.
Caution:
Do not remove any other labels or seals, or ink will
leak. Do not touch the green chip on the front of the
cartridge. This can damage the ink cartridge.
Sep 01, 2011 | Office Equipment & Supplies
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
It keeps showing the message "remove and check the right ink cartridge". we already removed and re-install it many times. we also cleaned it and we still show that message. help! thank you!
Try to replace the ink cartridge with a new name brand ink jet cartridge that matches the manufacturer. Sometimes aftermarket ink jet cartridges don't work as well as the name brand ones.
Dec 18, 2010 | Office Equipment & Supplies
Put new ink in printer. got the message "carriage jam" checked ink to see if correctly installed...it was. tried to use it again and same message appeared. Did as was instructed on Kodak...
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 15, 2010 | Office Equipment & Supplies
Keeps saying install c
When the printer says "install C" it is referring to the Cyan (blue) ink cartridge. If this is not a new cartridge, you might have to replace it. If this is a new cartridge, try following these steps.
1. Unplug the power cable.
2. Remove all 4 ink cartridges.
3. Close the ink cover
4. Plug the power back in.
5. Wait for the machine to warm up and tell you that the ink is empty.
6. Reinsert all 4 ink cartridges.
If you keep getting the same message you should try another cartridge. You can put the yellow cartridge in the blue spot to see if you get the same message. If you get the same message then the machine is broken. If you get a new message then the cyan cartridge needs to be changed.
Thanks,
Pat
Nov 09, 2010 | Brother DCP 130C All-In-One InkJet Printer
I don't know how to change the ink bought this printer from a guy at work no manual
Lift the scanner cover from the right-hand side of the MFC until
it locks securely into the open position.
If one or more ink cartridges are empty, for example Black, the
LCD shows Ink Empty Black and Cover is Open.
Pull the ink cartridge hook toward you and remove the ink
cartridge for the color shown on the LCD.
Open the new ink cartridge bag for the color shown on the LCD,
and then take out the ink cartridge.
Remove the cartridge covers.
Each color has its own correct position. Keep the ink cartridge
in an upright position when you insert it into slot. Press down on
the ink cartridge until the hook snaps over it.
Lift the scanner cover to release the lock. Gently push the
scanner cover support down and close the scanner cover.
If you replaced an ink cartridge while Near Empty was
displayed on the LCD, the LCD may ask you to verify that it was
a brand new one. Example: Did You Change Blck? 1.Yes
2.No. For each new cartridge you installed, press 1 on the dial
pad to automatically reset the ink dot counter for that color. If the
ink cartridge you installed is not a brand new one, please be
sure to select 2.
If you wait until Ink Empty message is displayed on the LCD,
the MFC will automatically reset the ink dot counter.
If the Install message is on the display after you have
installed ink cartridges, check that the ink cartridges are
installed properly.
Hope that helps you!
Aug 12, 2009 | Brother MFC 420CN All-In-One InkJet...
Keep getting replace yellow ink cartridge error message
Where did you get the error message on printer or computer?
If you get the message on printer remove all cartridges and reinsert the cartridges and align the ink cartridges. If the alignment page prints successfully then the problem is resolved.
If you get the message on the computer disconnect the usb from computer. uninstall the software and reinstall the full feature software by selecting connect USB later.
May 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Bought today a hP7200 All-inOne Series. Set up and received the following: Error message "Incorrect Ink Cartridge: The following ink cartridges cannot be used after device initializaed and must be...
hi friend
try remove your printer cardige & rinstall it if u have not remove your printer cardige nosel raper so remove tape of the nosel try to install & print
Apr 13, 2008 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
96 people viewed this question
Seeker5211
Seeker5211
