Question about Logitech Cordless Mouse
I don't know how to open the mouse to change batteries. What os the red button marked connect?
  • 8 Answers
SOURCE: Can't reset my cordless Logitech mouse
you should hold the reset button on the receiver for 5 seconds. let it go and immediately press the reset button on the mouse once. If done in this order it should be ok.
Posted on Aug 23, 2008
dnewcombe1
  • 1564 Answers
SOURCE: mouse not working. changed batteries, pushed
Reinstall your software with the install disk, if tha doesn't work, remove the ball from the bottom and take your little sisters toothbrush(just kidding) and clean the opticle points with it. There should be four of them. Good luck.
Posted on Sep 06, 2009
PCTechOnline
  • 532 Answers
SOURCE: I have a dell pc ~ 15 months old that was bought
These devices will never auto connect after a battery change. You must press the button on the receiver then the red button on the mouse. Then the button on the receiver again, then the red button on the keyboard. The buttons on the devices (keyboard and mouse are on the bottom of the device.
Posted on Mar 21, 2010
SOURCE: changed battery correctly but the on/off green light keeps blinki
you have to hit the button on the wireless base adapter as well as the one on the mouse its self
good luck and pls rate this post
Posted on Mar 23, 2010
byteguy
  • 2229 Answers
SOURCE: My wireless Logitech mouse stopped
So much for Wal-Mart tech support.
If your mouse is not working, first check the batteries to be sure they are good.
You wireless mouse has a USB "antenna" or sending unit. It may have a button on it that says "connect." If so, push it.
The mouse itself has a little button on the bottom that says "connect."
Push that one next. It should now work.
If it doesn't, switch USB ports and try again.
And no, we don't charge for this answer.
Posted on May 13, 2011
Toshiba satellite pro does not fully shutdown
In Control Panel, select Power Options, you didn't post your OS?, set to High Performance, open Change Plan settings, set Computer Sleep Never, open Change Advanced power settings, scroll through the settings, set Sleep and Hibernate to Never, open Power Buttons and Lid, set to shut down. Now the red X on the Battery Icon usually means the battery needs replacing, it's not charging. Shut down the Laptop unplug, remove battery, plug in , reboot.
May 12, 2013 | Toshiba Satellite Computers & Internet
My mouse keeps on skipping clicks, I don't know why. The wireless connection seems to be in order and everything else seems fine.
Did you try changing the batteries? If so, try unplugging the mouse receiver and plugging it back in. If that doesn't do anything, how long have you used the mouse? My mouse skips clicks because of my normal use over the years. Might just be the wear and tear to the little clicker button, but try changing batteries.
Jun 22, 2011 | Dynex Wireless Optical Mouse
My wireless Logitech mouse stopped performing. I changed batteries. the red light comes on even before I changed the battery. I have had it about 3 months. Wal Mart told me to look on the back of mouse. ...
May 13, 2011 | Logitech Cordless Mouse
I have a dell pc ~ 15 months old that was bought with logitech MX3200 wireless keyboard and mouse. My wife changed the batteries in the mouse but it did not automatically reconnect. On my return, I pressed...
Mar 16, 2010 | Logitech Cordless Desktop MX3200 Keyboard...
Help me make this wireless mouse work!
I had the same problem and after hundreds of tries i push the button on the receiver and quickly the red connect button on the optical mouse for about 5 seconds and it work... i don´t know if it´s a final solution but this time it work´d
Apr 23, 2009 | HP Wireless Optical Mouse
Logitech cordless mouse red light won't go off - New Batteries
Check the bottom of the mouse for a connect button. Push the connect button and it should work.
Mar 21, 2009 | Logitech LX5 Cordless Optical Mouse
Change batteries
This is a deceptive little beastie. As you look at the mouse, you will see that the front approximately 1/3 consists of the left and right mouse buttons and the scroll wheel. The rest appears to be a one piece cover with the black area with the GE logo in the middle. There's the tricky part. The black part with the Logo is the housing for the USB plug in part (so you can keep it with the mouse when transporting it). The rest of that (silver on my mouse) is the battery cover. You open it up by gripping the little raised line on each side of the cover and pull backwards while holding the front by the black area under the mouse buttons. The cover (only the silver part, the black is attached to the rest of the mouse) will slide backwards and Voila! There are your batteries.
Jan 12, 2009 | GE Optical Mini Mouse ho98094
My mouse will not operate my laptop Red Light is sometimes blinking. Do I need to change na battery in it, if so, how do I open the unit?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 09, 2009 | Logitech Wireless Optical Mouse...
Interlink 4350 wireless mouse won't work
You probably already tried this.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 03, 2008 | Interlink VP4350 Mouse
Targus mouse remote
If the Red Light is on the batteries should be good enough to function. Try
Feb 07, 2008 | Targus Wireless Remote Presenter Mouse
Logitech Cordless Mouse Logo
12 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
