Question about MB Quart - 6.5" Midrange Driver RWE 160 Car Speaker
How to wire mb quart rwe 160 up - MB Quart - 6.5" Midrange Driver RWE 160 Car Speaker
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: MB QUART WIRED REMOTE WRC-S1 NOT WORKING
test the LED hit any key viewing with digital or cell digital. see the diagram THE LED must be TURN ON, if not open the remote and clean the keypads contacts from dirty+corrosion+bad contacts+clean the contacts battery too and replace by new ones.Try it again.
God bless you
Posted on Jul 14, 2013
Testimonial: "God Bless you too ! however this is a fixed wired remote on a new boat.It displays but the function button do not work. they used to til we hooked up an I-PAD into the radios AUX to listen to music."
How do I wire a mb quart QXD 164 crossover to a kef kar kx3?
I would not recommend this.
Crossovers are designed with specific speakers in mind - they are not interchangeable, since the impedance (Resistance and Inductance) varies widely.
While this will not damage anything to try it, it will probably sound terrible as most people that have separates for the car audio are fairly particular about sound.
May 14, 2014 | MB Quart QSD 164 Car Subwoofer
Need help trying to locate.the Power and speaker plugs for Mb Quart RAA1000 monoblock 1975 Car Amplifier.
I am assuming you are referring to the actual connectors/plugs that are needed to wire the MB Quart RAA1000, a complete wiring kit is available here. It includes patch cord, power cable, grounding cable, turn-on lead among others.
If you want a pictorial layout of the wiring and connectors, the owner's manual would be of help and is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 09, 2008 | MB Quart Car Audio & Video
God bless you
Jul 14, 2013 | MB Quart WRC-S1 Round Wired Remote Control
AFTER OIL CHANGE MY ML350 OIL HI LIGHT IS ON AND WHITE SMOKE IS COMING FROM THE EXHAUST
They may have added too much oil -- a 2004 MB ml350 with a 3.7L engine should take only 8.5 Quarts (including what goes in the oil filter) -- Exactly 8.5 Quarts, no more, no less. You may be able do check the oil level by using the onboard computer - pushing the buttons on the steering wheel - follow the directions in the owners manual on how to check the oil level.
Aug 10, 2012 | 2004 Mercedes-Benz ML 350
Mb quart marine stereo fuse issues WR 1-CD
There might be some shorted component/s on the circuit board. Seek tech support.
Jun 02, 2012 | MB Quart ALX80IW Main / Stereo Speaker
How many quarts of automatic transmission fluid does a 2002 dodge durango with a 4.7 L take?
Dear SIR:
4.6 QUARTS in automatic t.
9.3 " in 4 speeds.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Mar 29, 2012 | 2002 Dodge Durango
I have a amp with switch that says high power & high current
The ohms rating measures the electrical resistance of the subs(impedance). On the subs there is usually a label that tells you what the impedance is for that particular sub,example= 4 ohms . The only way you can get to a 1 ohm load or less with a pair of tens is if each sub has dual voice coils that are 4 ohms each wired in parallel. Generally Sony xplod's are a single coil 4 ohm woofer-yours might be the exception in this case .To figure out your resistance say with 2 subs that are 4 ohms you have to know how you intend to wire them for instance if your amp puts out a fair amount of power @2 ohms and thats the number you want to hit than you will want to wire the subs in parallel( + to + and - to -) wiring in parallel lowers the resistance.(ohms) If you want to hit 1 ohm and you have dual 4 ohm coils then wire all 4 coils in parallel and that will then be a 1 ohm load. Its simply a matter of dividing the ohms by the number of speakers that you intend to connect. if you had 3 10s that were 4 ohms each and you wired them in parallel the ohms would be 1.33 (as 4 divided by 3 is 1.33)(4 divided by 2 is 2) (4 divided by 4 is 1) On the flip side wiring in series will raise your impedance-a pair of 4 ohm subs wired in series gives you an 8 ohm load 3 subs gives you 12 ohms and so on. I wouldnt worry about the high current switch unless youre planning on taking it down below 1 ohm which it sounds like you arent currently set up for.
Jan 31, 2010 | MB Quart RWE 352/354 15" DVC Subwoofer Car...
I need to know who is better for my cherokee sport 1999 ..!!!
Hello leonardoe,
The MB Quart's are component speakers and the PPI's are coaxials. In an "apples to oranges" comparison, the MB Quarts win. Most component systems in the same price range as a coaxial will have better sound imaging simply because you can mount the tweeters up high for better high frequency dispersion. Some also allow you to make adjustments to the crossover, which is built-in and fixed on the coaxial.
But component systems are more difficult to install. If your vehicle doesn't already have the wiring for separate tweeters, you have to install it. Likewise, the mounting of separate tweeters adds to the installation complexity.
Hope this helps.
Jul 15, 2009 | PPI PC650C Coaxial Car Speaker
I want to make this sub a 1 ohm. how do i do that?
to run this at 1 ohm, connect one terminal to your amplifier and then run a line from that terminal to the other terminal, in parralel, which means positive to positive and negative to negative in all cases. a wire starts at one terminal, goes into the next terminal and continues to the amp.
To run at 2 ohm just connect one terminal to the amp, no need to make a connection between the two terminals, just choose one!
to run at 4 ohms, u have to wire the sub in series, which means you connect the negative of the amp to the negative of one terminal, and the positive of the amp to the positive of the OTHER terminal, and a wire should connect the negative and positive from each terminal.
This is assuming that your subwoofer has two 2ohm terminals.
be careful what you amplifier is stable at. running 1 ohm on a 4 or 2 ohm stable amp can and eventually will over heat and destroy it.
Mar 21, 2009 | MB Quart RWE 352/354 15" DVC Subwoofer Car...
Can't find Power and Speaker Plugs For Mb Quart RAA1000 1975 mono block Car Amp.
Probably not. The best thing you can do is either contact MB directly or go to a shop that sells that amp and ask them.
Jul 09, 2008 | MB Quart RAA1000 Car Audio Amplifier
MB Quart - 6.5" Midrange Driver RWE 160 Car Speaker Logo
157 people viewed this question
Top MB Quart Car Audio & Video Experts
xxxxxx xxx
Are you a MB Quart Car Audio and Video Expert? Answer questions, earn points and help others
