Question about HP Compaq nc6000 Notebook
No light on power/standby at power on. Replaced the battery, and put it to charge. Starting up, logging in, system hangs. Holding down power key to stop. Then no green light on power lamp and the pc won't start. Wireless and charging lamp lights up, but no poer lamp
  • HP Master
  • 6,771 Answers
What you are describing is a motherboard issue, the unit will need to be taken apart for closer inspection.
Posted on Jan 02, 2011
Can a faulty theft system drain your battery?
No an anti-theft system can not drain a battery. Only two things can, with a couple of other caveats.
  1. Faulty, old battery not holding charge.
  2. Parasitic draw, something that is staying on and draining the battery. These are difficult to find. The way to do it is to connect an ammeter to the battery and pull the fuses one by one until you find the items that are shorting to earth.
Some anti-theft systems provide no power to the starter at all. Some send power power to the starter, but no power to the coils, so no spark.
Disconnect the battery and clean the terminals with a wire brush and smear with vaseline which stops oxidisation but is electrically conductive.
Charge the battery with a battery charger.
Leave battery disconnected overnight.
Put the key in the ignition, but not turned on. Connect the battery in one swift movement. Tighten contacts. Leave 15 minutes for the ECU, to reset, and the chip in the key and the chip in the lock to re-pair.
Jul 27, 2017 | 2002 Chevrolet Malibu
Toshiba satellite may be stuck in Standby or hibernation mode. i TRIED HOLDING THE POWER BUTTON FOR 10 SECONDS AND RESTART, THAT DID NOT WORK. CANNOT GO INTO SAFE MODE. hELP
It sounds more like there was a charging issue and not enough juice left in the battery to start it up. Try removing the battery and then putting it in again. And then try starting it up. The adapter may be shot. Some laptops won't work if the battery is out or is shot even though the adapter is plugged in. Batteries generally need to be replaced every few years.
Also watch the lights on the front to see if they're coming on when you press the power button.
Jul 04, 2011 | Toshiba Satellite A135-S2386 Notebook
My garden tractor is not holding it's battery charge. I replaced the battery, but still doesn't hold a charge after I use it.
If you replaced the battery with a new one and it is not holding a charge, then your charging system is not putting out enough power to run the mower AND recharge the battery. So you need to figure what is wrong in the charging system.
Mar 26, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
HP STUCK IN HIBERNATION MODE. HOW DO YOU FIX?
*Take out the battery,
*Remove main supply,
*Hold power button down for 30 secs,
*Put only power supply in, do not put battery in
*Turn laptop on
*Put the battery in.
or this:
1. Remove power supply and battery.
2. Hold power button down for 30 seconds.
3. WHILE STILL HOLDING DOWN POWER BUTTON, INSERT POWER SUPPLY, THEN INSERT THE BATTERY. *THE POWER BUTTON SHOULD BE HELD, THROUGHOUT THIS ENTIRE STEP.
4. At this point, the blue light and the charging light should both come on, and the computer should start properly.
And check ur operating system for errors by downloading reginout
Aug 16, 2010 | HP Pavilion dv6000z Notebook
My vector start-it elite jump starter is not holding charge even after days of charging. Why?
Hi Ydja,
The batteries on these jump boxes don't last very long. I've been through three of them. Never again.
Now I just carry an extra battery. It's more powerful and has laste longer than the three jump boxes put together.
Best regards
Mike
Dec 12, 2009 | Vector VEC010S Jump Start System 300 Amp...
HARMONY 880 SAFE MODE???
remove the batteries2.gif from the remote
hold down to the number 2 key
as you are holding down to the number 2 key (do not let go of this number key) put the batteries back in
now remove the batteries again and put it back in again without pressing any buttons
if this does nto fix the issue
remove the batteries from the remote
do a firmware upgrade
Aug 01, 2009 | Logitech Harmony 966208 Remote Control
My acer aspire one hangs when i set to standby mode
You don't specify but it seems like you are using Windows. This problem can be caused because you didn't set up an Account name. You can add one user, give yourself full admin rights, and do NOT require a password.
Default in Windows from standby is to log in as user...it goes wonky if no user is set. It can't find the user and does not know what to do, you have to reboot to get out of it, all stuff saved is lost.
BTW When you are at the Standby screen, hold down SHIFT key and it will change to Hibernate, if that option is available. Hibernate saves all your stuff to the hard drive and powers down..much better for batteries than Standby
Hope this helps
Jun 12, 2009 | Acer Aspire One PC Notebook
Onkyo HT-SR800 won't turn on
If you call Onkyo directly, 201-785-2600, there is a procedure to "reset" the system, something like holding the power button on and holding down another button for a few seconds. Can't remember which, so I can't be sure, but try giving them a call.
Jan 02, 2009 | Onkyo HT-SR800 System
The power cable light on my Toshiba Portege 2010 flashes yellow/orange when the plug is inserted. Computer will not turn on (green light on power button doesn't even come up). Have tried: 1) starting up...
One thing could be that your A/C adapter has failed resulting in your battery not being charged. This would explain why you're experiencing the same symptoms w/ or w/out the A/C adapter.
Apr 04, 2008 | Toshiba Portege 2010 Notebook
HP Compaq nc6000 Notebook Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
