Question about Canon CanoScan LIDE50 Flatbed Scanner
Hello, I keep getting ScanGear CS Error 2,7,0 on my Canon Lide50. The calibration window appears for 10 seconds or so and during that time I can hear the scanning head move and I have seen the LEDs flicker white/blue and red. I have a second Lide50 and that works perfectly when I switch scanners. I would be most grateful for any ideas you have. Many thanks Philip
2 Suggested Answers
SOURCE: Canon ScanGear CS driver error Code: 2,252,0 - Can't preview
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Posted on Apr 27, 2009
Error massage
follow this steps and fix it. Merry Christmas
The Steps for Newer Style Console Calibration
1.Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2.Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3.Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4.If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5.Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6.Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7.Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8.Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9.Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10.Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12.Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13.When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14.Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Reset:
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Life Fitness F1 Smart Treadmill
I'm getting 2 error messages when I import the Canoscan D1250U2F from Photoshop: 1) ScanGear CS-U: Cannot communicate with scanner. Cable may be disconnected. Check status. Scanner driver will be...
I have many years experience repairing Canon scanners so here is my suggestion for you.
This is a common problem with all Canon scanners. If you do a lot of scanning or leave your computer on all the time and never shut it off. What is happening is the memory fills up with all of the images and it needs to be cleaned out. If you reboot (restart) your computer it will clean out the memory and your problem will go away. I always recommend that if your going to be scanning a lot then do it off a fresh reboot and you should be able to your hearts content.
I hope this helps you out.
Mar 04, 2011 | Canon CanoScan D1250U2F Flatbed Scanner
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
1. Save these on C:
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
Canon 8400F scanner refuses to scan 12 negatives at a time. Preview shows them all, but the "select all frames" is grayed out, and refuses to function. I can scan manually one negative at a time among...
Check to see if the "Thumbnail Display" is on or off (first icon on the toolbar in the ScanGear CS window). If it is on, a colored border will appear around one of the images in the preview display, but you will not be able to select all frames. If you click on the Thumbnail Display icon to turn it off, only a dotted line will appear around one of the images, but you will be able to click on the "select all frames" Apply button.
Dec 09, 2008 | Canon CanoScan 8400F Flatbed Scanner
Scangear Error
i think this problem come with windows xp update!
when u started to see this messege?
Nov 30, 2008 | Canon MP610 Photo All-In-One Printer
Canoscan 4400F & Vista
It looks like the computers have a hard time communicating with the scanner it will be advisable to download all the current firmware available, her is the link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=13810#DownloadDetailAct
This should take care of the problems.
Oct 19, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan LIDE50 Flatbed Scanner Logo
396 people viewed this question
old marine
old marine
