Question about Neovo E-17 17" LCD Monitor
My ag neovo e-17da monitor everything in the screen seems to have stretched and the bottom of the screen where the arrow is to scroll up and down i cant see it its like i need to shrink the display a little and the writing is not very clear but i dont know how any help would be great many thanks ,dean
  • 696 Answers
Hello Dean,
It seems your windows resolution settings are set wrong, you simply need to adjust the resolution to match the monitor. To do this, open your start menu, select Control panel. When the control panel is open check the top left corner to see if it is in Classic or Category view, if it says Category, click the switch to classic mode link. If you don't see this in the top left look at the top right and look for Category or Large Icon View, if Category is selected select Large Icon by clicking on Category and then clicking Large Icon View in the list that appears.
Once in the proper view, click on Display and depending which version of windows you have select Settings on the top of the properties window(XP or older) or Adjust Resolution from the left column(Vista/7), now find the slider bar for resolution and slide it to 1280x1024. This will set the number of pixels on the screen.
The default and best resolution for this monitor is 1280x1024, if that makes the fonts/icons too small try 1024x768 next and 800x600 last. If the resolution is set too low to see the Ok and Apply buttons simply set the slider bar then press the enter button the first time, then you will be able to see the Ok and Apply if you need to continue adjusting.
Hope this helps FixYa,
Chris
Reply back with your version of windows if you require more specific instructions or pictures of any of the steps.
Posted on Jan 02, 2011
I have a perfect second hand Neovo 17DA monitor, but I don't have the installation disk so that I can take advantage of the build in speakers inside the monitor. What can I do about this? I've tried to...
Well, a driver is not required to use the internal speakers! You just have to plug the OUTPUT from your computer sound card into the input jack on the rear of the monitor. For this, of course, you will require a suitable lead (or cable) with stereo jack plugs on each end. The sound output from the speakers is only 1 watt so don't expect wonders..but it does have a headphone socket so it would make a convenient point for you to plug your headphones to, but of course, you've got to feed the output from your sound card to the monitor first. Regards, nicam49
p.s. please don't forget to vote :-)
Feb 01, 2011 | Neovo E-17Da Monitor
I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN GOES BLANK AFTER ABOUT 5 SECS. TURNING OFF THE MONITOR THEN TURNING BACK ON BRINGS THE SCREEN ON FOR APPROX 5 SECS BEFORE GOING BLANK AGAIN. THIS IS REPEATED...
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
May 25, 2010 | Neovo AG 17" LCD Monitor
Monitor options flashing on screen how do I remove it
It might have a button stuck on it. Does it come on and stay on, or does it come on and go off continuosly?
To exit, press "Auto" once to save changes & return to main screen, push it again to exit the OSD. Assuming everything is functioning properly.
Jan 07, 2010 | Neovo AG 17" LCD Monitor
AG Neovo Monitor not working
nothing you can reset from monitor other than color brightness. You can contact with AG Neovo as service.us@agneovo.com to have a RMA number and they will estimate you the repair fee if it is out of warranty.
Jan 06, 2010 | Neovo E-19A 19" LCD Monitor
Monitor switches off!
An internal circuit may be failing.
Jul 03, 2017 | Neovo E-17DA (Black) 17" LCD Monitor
Monitor shows cctv for 2 seconds then goes of? Why.sx 17a monitor
Dear sir pls match the colur system standard of CCTV out & ur monitor Video in , U might be using a PAL camera on NTSC input or vice versa
1) ur monitor may not be supporting low resolution try NTSC/PAL to VGA convertor box ..
Mar 20, 2009 | Neovo AG 17" LCD Monitor
Power problem?
Try ordering a new power adapter from Neovo. Call them up. It could't hurt. Apparently adapters are tricky items. I have no idea how much they cost, but if its reasonable it would be a fair tade for the nuisance you are dealing with now.
http://www.neovo-usa.com/
AG Neovo Technology Corporation
2362 Qume Drive, Suite A
San Jose, CA 95131 U.S.A.
Email: rma@neovo-usa.com
Tel: 408-321-8210
Fax: 408-321-8211
Nov 14, 2007 | Neovo E-19A 19" LCD Monitor
Screen goes black in half a second....
Call the service dept. in the above post. Tell them the model and serial number of your monitor and order a backlight inverter board(approx. $35 plus shipping). Open up the monitor and plug it in, should fix the problem. This problem could also be caused by one or more backlights(small flourescent tubes) being bad. I just fixed a Neovo F-417 display by replacing one of the backlight assemblys. I also just fixed a Neovo E-17DA monitor by replacing the inverter board.
Oct 30, 2006 | Neovo E-19A 19" LCD Monitor
Screen is gone in half a second....
could be the lamps or the inverter board
Oct 27, 2006 | Neovo AG 17" LCD Monitor
Neovo E-17 17" LCD Monitor Logo
123 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
