Question about Microsoft Xbox 360 Console
Can a scratch be removed from a game disc - Microsoft Xbox 360 Console
  • 162 Answers
It dependes on how deep the scratch is if it is shallow then yes if deep then mabye
Posted on Jan 02, 2011
On my xbox it tells me to cleen the disk and then restart the xbox so i do but it keeps doing it still
all discs or specific one, try running lens cleaning disc, might be that the lens itself is whats dirty and not the game
Jun 22, 2010 | Microsoft Xbox 360™ Premium White Console
Tip
Check to see if there are any scratches or laser burn marks on the discs....
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
on Apr 03, 2010 | Video Game Consoles & Games
Tip
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
on Jan 23, 2010 | Video Game Consoles & Games
WHEN I GOT A NEW GAME IT WAS WORKING BUT A COUPLE OF DAYS LATER IT SAID THE DISC COULD NOT BE READ AND IT TOLD ME TO CLEAN IT WITH A SOFT CLOTH AND RESTART THE CONSOLE AND I DID IT AND IT SAID THE SAME...
Check to see if there are any scratches or laser burn marks on the discs. If there no scratches evident on the disc, try a laser lens cleaner, these are normally quite cheap.
Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
May 20, 2010 | Microsoft Xbox Console
My Xbox 360 keeps scratching my game discs?
Sounds like the xbox console needs the laser adjusted or secured as per the other comments. For any discs issues, read on.
Check to see if there are any scratches or laser burn marks on the discs.Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
www.discREPAIR.ie
Hope this Helps!!
Apr 07, 2010 | Microsoft Xbox 360 Console
Disc is scratched. It has not been removed from
If the Game is scratched there isn't much you can do. I would advise you to go to your local video game retail store, and ask them about their disc buffing. In st.catharines ON at EB games, they charge you 12$ to buff the disc, and the disc comes out like its new, and 99% of the time it works. Hope this helps and please rate.
Feb 23, 2010 | Microsoft Xbox 360 Console
I bought a psp game that had a tiny scratch and now it freezes and osent load, can anyone tell me what to do besides taking it back?
Try cleaning the disc and using one of those Disc Doctor things, or scratch remover cream, to remove the scratch. You can also get the disc refaced at a local game store.
Feb 14, 2010 | Microsoft Xbox 360 Console
Fifa 09 football problem. telling me to clean disc as it is unreadable i am cleaning the disc and restarting the console but it keeps telling me to clean the disc.
OR
Jan 23, 2010 | EA Sports Video Game Consoles & Games
How to repair nba 2k9 for xbox 360
When I have problems with scratched DVD's or games, I use the scratch remover cream that goes on your disc, Leave it on for a few minutes to dry, then wipe it off with a very smooth cloth... Its about $7 or $8 I think.... Good Luck, Like I said this usually works fine for fixing scratched discs
Oct 18, 2009 | 2K Games NBA 2K9 for Xbox 360
Microsoft Xbox 360 Console Logo
19 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
