Question about Sony VAIO V1 (PCV-V1) PC Desktop
How to open the casing and change the CMOS battery on the Sony pcv-v1? leecom77 has described it is on the mother board, but I need step by step guide or a service manual. Cheers, Alex
3 Suggested Answers
computerdeb
  • 323 Answers
SOURCE: SONY PCV-V1/G
Use this link and click detect my model on the right.
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1
Posted on Mar 18, 2010
Testimonial: "worked nice also amazed at fast responce muchos gratias my friend"
leecom72
  • 4806 Answers
SOURCE: Hi, I've a Sony Vaio Desktop
The CMOS battery is located on the motherboard inside the AIO and looks like this >>>>
You will have to take apart the All in one to get to the battery.
Regards.
Posted on Aug 05, 2010
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
Please can you tell me the location of the cmos battery on pcv-af1m we have the back off and have been looking for for 8hours
Generally all Cmos batter available in front panel place. If you are used PC then open cabinet and see mother board front panel silver color small batter available.
If you are used Laptop then same place available other wise RAM slot nearest.
Thanks..
Oct 14, 2013 | Sony VAIO PCV-W20 PC Desktop
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
Need to change battery
Presumable you mean the CEMO battery take the side cover off look around the mother board you will see a small silver battery which retains the clock timing it will be retained in a round clip holder change it. Presumable you have to press F1 on boot up to continue this indicates a dud CMOS battery.
Sep 13, 2010 | Sony VAIO PCV-W20 PC Desktop
VAIO PCV-W20 PC Desktop I need to change the CMOS battery, how do I get the motherboard out so that I can replace the battery?
Hi
You shouldn't need to remove the board to change the battery.
Just to be sure,this is a desktop and not a laptop,right?
If so,remove the side panel,or open the case if it opens without panels coming off.You'll see the battery somewhere on the board,it's about the size of a quarter and will be a CR2032.Just remember which side goes in first.
Bob
Aug 21, 2010 | Sony VAIO PCV-W20 PC Desktop
Hi, I've a Sony Vaio Desktop (all-in-one) PCV-V1/G. Where is the CMOS battery located so that i can replace it as it. Thanks in advance.
Regards.
Aug 05, 2010 | Sony VAIO V1 (PCV-V1) PC Desktop
How do i fit extra ram in this all in one pc/media center Sony PCV-V1G it is impossible to gain access to the inner workings?
every computer case has an opening and if your motherboard has more slots for ram than one you can buy one for *********** board but make shure it is the same as the one you already have in it.
Sep 26, 2009 | Sony VAIO V1 (PCV-V1) PC Desktop
Sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Oct 11, 2008 | Computers & Internet
Replacing cmos battery on acer 529atx
hi dear
it's easy way to change your cmos battery, open your casing, see it besides bios. just take it, and change with new one
oke
cropp
Mar 29, 2008 | Computers & Internet
Sony VAIO V1 (PCV-V1) PC Desktop Logo
196 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
