Question about Ranger Communications RCI-6900F-25 CB Radio
RCI 2950 WORKS FOR ABOUT 3 MIN THEN STOPS TURN OFF FOR TEN MIN WORKS AGAIN
  • 204 Answers
Hello, Just offhand I'd say you have a bad solder joint on the main circuit board. Without more info, I can not tell you where to look,,,,, Mechanic
Posted on Nov 06, 2008
Have you talked to the company about your <a rel='nofollow' href="http://www.jokermancbelectronics.com/">ranger cb radios</a> problems? Oftentimes they can give you helpful tips for fixing it or they will replace it outright. Give them a call; I bet they can help, even if it is an older model.
Posted on May 10, 2011
Why would my rci 2950 work at lower watts 'but when i turn the watts up the meter drops and the radio shuts down? I can turn it off and back on and it works again till i try to turn the rf power up '
you are probably heating up the final at the high output and thats whats happening.Could also be somethig else.Take it to a tech and have them look at it.
Sep 30, 2014 | Radio Communications
On the Ranger RCI-2950 will the display stop working if the internal battery gets old or flat. Mine comes on and works for a while then after about 20 mins a few legs of the display starts flashing on and...
Get some freeze spray and when it starts fading spray the components and see if it comes back. This is an overheating issue and not a battery issue
Jun 01, 2013 | Radio Communications
Where can I get a cpu board for my ranger 2950?
get hold of ranger and they should be able to help you.
Mar 18, 2013 | Radio Communications
Ranger rci 2950 will not transmit
have you tried it on all bands? still won't transmit?take it to a tech so they can fix it properly.
Sep 16, 2012 | Ranger Communications RCI-6900F-25 CB...
Radio comes on numbers do not show,beeps all the time
What kind of radio is it.. RCI?? or other.. IF its a rci 2950 stlye there is a pin on the panel of the radio inside. this will reset it back to 28mhz. then put it back, it may work. if it doesn't it will be a more major problem possibly.
Dec 04, 2011 | Radio Communications
I have a RCI 2950 comes on keyed up and stays keyed untill you turn it off. I have replaced the auto amp, all voltage regulators and the black diode with yellow strip below mic plug with no change. I need...
i have the same radio rci 2950. Ive had the same problem with mine,turns out with mine the processor would lock up,turning the radio off & on repeadly would clear the problem and the radio would work fine x-mit & recieve. the solution to fixing the problem is to replace the memory backup battery this battery works similar to a computer motherboard cmos battery when this battery goes dead all sorts of strange things happen to the radio wont transmit wont recieve or like your problem transmits continiously. the problem with replacing this battery is finding out what year & model your ranger 2950 is. the internet says only first generation ranger 2950s use the battery second genration & third generation do not use the battery. but the internet could be wrong. so i suggest getting a hold of (usa ranger.com) & give them a phone call or email and ask them about the year your radio was made. they may even service it for you or if you are electronic savvy you can do it yourself. the battery is located close to the main cpu on the front panel if yours uses a battery.
Sep 07, 2011 | Ranger Communications RCI-6900F-25 CB...
2950 RCI WONT TURN ON ONLY A BACKGROUND LIGHT
You either have a bad LCD display OR the connection for the LCD display is loose/off. Its impossible to tell what channel you are on with a 2950 without the screen working, but when you turn the channel knob do you hear any other cb transmitting on ANY channel?? This is a tough one!! I really need some more info on the radio.
Open the case and look at the area that the display is in (front of radio). Slightly wiggle all of the little plugs in that area. If you see the LCD screen come on or flash then you know where your problem lies. If not, then you're probably looking at buying a LCD display for the radio.
Good luck.
Feb 16, 2011 | Ranger RCI-6300F-25 CB Radio
Lack of receive on a ranger 2950
Bad mic? dirty mic pins? If the mic is bad, you will have no receive.
Nov 10, 2009 | Ranger RCI-6900F-25 CB Radio
No channel readout in front of radio ranger 2950
replace memory battery its a CR2032 battery Radio Shack and Walmart has them from $3.65 to $5 in price.
Jan 11, 2009 | Ranger Communications RCI-6900F-25 CB...
Ranger Communications RCI-6900F-25 CB Radio Logo
511 people viewed this question
Top Ranger Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
