Question about HP DeskJet 3650 InkJet Printer
My printer won't print because the cartridge cradle can't move.
    Sergeant:
    Champion:
  • 342 Answers
When the printer is on can you grab the cradle and pull it out of where it is stuck because if you do that then you might free up the cradle jam
Posted on Jan 02, 2011
I can't seem to install my ink cartridge correctly. Do you have a picture demonstration on how to do this? I continue getting an error message.
Installing the print cartridges Follow the instructions below to install the print cartridges: caution.png CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  1. Remove the print cartridge from its packaging and carefully remove the plastic tape from the copper strip. Figure 2: Removing the plastic tapec00109809.jpg
  2. With the power on, open the printer's top cover. The cradle moves to the center of the printer.
  3. Hold the print cartridge so that the copper strip is on the bottom. Figure 3: Holding the print cartridgec00109811.jpg
  4. Insert the cartridge into the cradle at a slight upward angle until you feel resistance. Figure 4: Inserting the print cartridgec00109813.jpg
  5. Firmly push the cartridge into the cradle. You will hear a snapping sound when the print cartridge is correctly positioned. The print cartridge fits securely in its cradle. Figure 5: Print cartridge in correct positionc00109815.jpg
  6. Close the top cover.
  7. Calibrate the printer for optimum print quality.
    Best of luck!
Sep 06, 2011 | HP Office Equipment & Supplies
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
How do i change the ink cartridge on my printer
These are the steps on how to install/replace cartridge(s) on Hp Deskjet 5550.
  • Press the POWER button to turn on the printer.
  • Open the top cover. The cradle moves to the center of the printer.
  • Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts of the print cartridge meet the copper contacts of the print cartridge cradle.
  • Close the cradle latch.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 19, 2010 | HP DeskJet 5550 InkJet Printer
Left ligh keep flashing. after installing new ink.
  • Make sure cartridge is placed in properly,
  • Re seat the cartridge and check.
  • It should work
Please rate my response!!
Jan 29, 2010 | HP DeskJet 940c InkJet Printer
All lights keep blinking!tried unplugging and reinstalling.Dead?
If the Resume c00121686.jpg light continues to blink and the print cartridge cradle does not move to the right side of the printer, try these solutions:
  • Remove and reinstall the print cartridges. Verify that the print cartridges are in the print cartridge cradle before pushing them forward into position.
  • Verify that no obstruction prevents the print cartridge cradle from moving freely on the rod.
  • Verify that the vinyl tape has been removed from each of the print cartridges.
If the problem persists, contact HP Customer Care.
Jan 14, 2009 | HP Photosmart C3180 All-In-One InkJet...
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
Insert the print cartridges
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
The print cartridge cradle cannot move.
"The print cartridge cradle cannot move."
I fixed this problem by disconnecting the power cord from the power-strip and connecting it directly into the wall. My printer was not getting enough voltage from the power-strip. I hope this helps.
Nov 18, 2008 | HP Photosmart C3180 All-In-One InkJet...
Change ink cartridge
Here is the procedure to change the ink cartridge
  • First Press the POWER button to turn on the printer.
  • Open the top cover.The cradle moves to the center of the printer.Open the cradle latch.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts the print cartridge meet the copper contacts of the print cartridge cradle
  • Verify white paper is loaded in the printer, then close the top cover. The printer automatically prints a calibration page for optimum print quality.
good luck:-)
Oct 08, 2008 | HP Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
HP DeskJet 3650 InkJet Printer Logo
263 people viewed this question
Seeker5211
Seeker5211
