Question about Kenmore 22422 Top Load Washer
Water inlet valve Kenmore dishwasher
Hello I just purchase a Kenmore portable dishwasher , model # 587.1744590 , it runs thru the cycle but no water comes in . is the the water inlet valve ?? easy to replace ?? cost ?? I am pretty handy . thanks Mike
  • Anonymous Mar 31, 2014
    I have a Whirlpool washer model GSX9750PW0. I want to know if the water inlet temperature sensor is built into the water inlet dispenser valve. thanks WB
    I have a Whirlpool washer model GSX9750PW0. I want to know if the water inlet temperature sensor is part of the water inlet dispenser valve. Mike
  • 5,911 Answers
Okay handy Mike,
First of all, is this a new dishwasher? Or, is it a used one? The reason I ask is because there should be a warranty with a new appliance and you should not have to worry, or have to pay for, any repairs.
The problem you are experiencing could very well be a water inlet valve problem (good assessment), but may also be something more simple. The dishwasher has a float inside the tub that is supposed to shut the water off, when it reaches the appropriate fill level. Check the float to make sure it moves up and down and that you can hear the switch "clicking". Sometimes small items get stuck under the float and will keep in the up (or shut off position).
For some helpful part locator drawings refer to searspartsdirect.com and type in your model number. An illustration of the water inlet valve can be found under the "Frame" heading in the next page as item number 24 (part number 154195301). The float and float switch can be found under the "Tub" heading as items number 13 (part number 154144301) and 24 (part number 5300809863), respectively.
If you require further assistance, please let me know. I hope its something simple and you don't require parts. But, if you do, you know where you can get them. If you do not wish to order on line, use the part numbers provided and go to your nearest appliance parts retailer. I hope this helps you. Good Luck.
Jeff
Posted on Jul 09, 2008
Have a portable kenmore dishwasher model 6651772200 which is not letting much water in...checked the floater valve and found it just sitting there but won't thread or snap into place or anything? Cleaned the residue from shaft of floater and it seemed to increase water intake but not as much as it should, should a new part snap into place?..there's no screw assembly on this part, or am I totally off base trying to figure out what the problem is? Many thanks
Posted on Jul 20, 2010
Dishwasher keeps running to long
Most likely the hot water temperature is the problem. If you have a separate hot water inlet check that the water temperature is ok. But if you only have a single cold water inlet then the heater inside dishwasher may be faulty. Check if the dishwasher is still cold when you terminate the cycle.
Heater is part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-66515752000/0582/0130000/P0101063/00003?blt=06&prst=&shdMod=
Apr 04, 2014 | Kenmore 665
Kenmore elite dishwasher valve # 8531325 let water run outside the dishwasher. I removed the valve inlet and nothing seems to be wrong with it. When I start a cycle, the water splashes out the valve...
It is likely the water pressure is too high for the dishwasher. Can you check if the setting has not shifted to Low pressure. Try to run the dishwasher with mains tap feeding water inlet to a lower setting.
Jun 12, 2012 | KitchenAid 24 in. KUDS02FRSS Stainless...
Hello, I recently installed a new faucet in our kitchen, hence turning the water. Not aware that my wife tried to wash dishes in the dishwasher before i turned the water back on, i think she damaged our...
Without a brand and model number, here is my best thoughts on what to check;
1) Was the shut off valve for water going to the dishwasher turned on after new faucet install? Is it turned on now?
2) Is water getting to the dishwasher water inlet control valve?
3) If water is getting to the water inlet control valve, unplug the dishwasher and check the solenoid to see if it is shorted. Unplug the solenoid. Using an ohm meter, check for 500-1000 ohms resistance. If there is no resistance, it is most likely shorted and needs to be replaced.
Sep 05, 2011 | Kenmore Dishwashers
We have a very old dishwasher purchased in 1993. The model is DWU9200AAX, and the serial number is A178671AALL. It has problem. When the dishwasher is turned off, it stores water. In two days, water...
If the problem you're experiencing is that after the cycle is done the tub is a dry.Yet within a few days their is water in the tub without you running it?
The problem is going to be the water inlet valve is seeping wate rand not fully closing. To fix that the water inlet valve will need to be replaced.
If that describes what your experiencing the replacment part for water inlet valve is part# 99001359
it could be purchased at your local appliance parts store or online at;
repairclinic.com
apwagner.com
appliancepartspros.com
apdepot.com
I hope i have been able to help you fix your dishwasher,
Gene
Aug 16, 2011 | Maytag Dishwashers
My Kenmore Portable Dishwasher model number 665.17769K600 will not fill with water, I have to manually fill with water and it will then work. What could be causing this?
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 24, 2011 | Kenmore Dishwashers
HI, Dishwasher does not have water supply anymore? TXS, Diane 450 447 7394
It seems the water inlet valve is old. Remove this part and replace. The water inlet valve can be found underneath the dishwasher.
If you can provide me the right model number of your dishwasher then I can direct you to where to purchase the parts.
Let me know..
Feb 15, 2011 | Kenmore Dishwashers
NO WATER IN ANY CYCLE. WATER LINE OK.
Hello
If you have already checked the water line for clogs and its clean then its the water inlet valve thats causing this problem. Please try to clean the inlet screen for any clogs and hope you understand if cleaning won't solve the issue then recommended repair is water inlet valve replacement. Please get back to me if you have any other questions.
Kevin
Nov 10, 2010 | Kenmore Dishwashers
No water
Two things to check. First see if anything is holding up the float inside the tub. Located on the bottom right if I remember correctly. I had a fork fall off the rack and do the exact same thing by getting lodged under the float. Second, if there was work done on the plumbing, some debrs may have gotten into the line and clogged things at the inlet valve. You may have water flowing through the inlet line, but maybe clogged at the valve. Need to take that off and check. While you are down there run the dishwasher through a cycle and test voltage at that valve. Also could be the valve or the control board.
Jul 14, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My portable dishwasher runs a complete cycle seemingly fine but with no water
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most
Apr 09, 2010 | Whirlpool 24 in. Portable Dishwasher...
Washer runs but no water
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the whole valve assembly. These are inexpensive and easy to replace. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles your is a whirlpool style. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available
Mar 30, 2010 | Dishwashers
Kenmore 22422 Top Load Washer Logo
1,028 people viewed this question
Sal De
fordexpert
Robert Rankin
