Question about KitchenAid 24 in. KUDP02FR Built-in Dishwasher
I cannot figure out how to get the nut off the water spinning bottom peice. not sure what it is called. I assume that is where the unit needs to be cleaned out because the dishes and glasses are not cleaning well at all.
  • KitchenAid Master
  • 43,501 Answers
Of ten those nuts are lefthand thread which means that instead of the normal righty tighty they are righty loosey...they turn opposite of what you think to loosen them...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jan 04, 2011
LG 8kg Fuzzy logic top loader and it will wash and fill the water but the water wont stop when it wash, rinse or spin it, the water also come out even there is no power to the machine.
Assuming the water is coming in even when unit is unplugged from wall. You should to replace the water inlet valves where the hoses connect to the machine. You need to unplug the power and remove the top, disconnect the hoses unhook the wire harness plugs, unscrew the hose valve hex nut and remove valve. Install the new one in reverse order.
May 16, 2011 | Washing Machines
How to change a belt on a Whirlpool washer model LA555OXTWO
I am not exactly sure on your machine, several places called it a direct drive unit but here are some directions I have found also.
1) Turn off water. Disconnect electrical supply and water hoses.
2) Remove agitator and cap from machine ( this is not always possible as the agitator gets frozen on the shaft, it just makes the job a little easier )
3) Lay machine on it's front. Protect front of the unit from scratches. Do not leave it over night on it's front as some oil will leak out the breather hole on top of the transmission.
4) Remove rear service panel
5) Loosen both nuts holding the motor mounting bracket in the slotted base plate holes. (see figure 1)
6) Rotate the motor to the right to relieve the belt tension and remove belt from motor pulley
7) After belt is removed from motor pulley, rotate motor to the left as far as possible to assure cam bar clearance.
8) The spin cam bar must be advanced to the spin position. Push up on the spin control solenoid plunger and rotate the main drive pulley until the cam bar advances to the spin position.
9) Remove the brake yoke spring from the gear case cover and yok. (see figure 2)
10) Remove completely the 3 support braces attached to the gear case and base plate. (see figure 3)
11) Remove the 2 pump mounting bolts. The pump hoses do not have to be disturbed. (see figure 3)
12) Remove the gear case mounting stud which has the spacer. remove spacer (see figure 2). Loosen the remaining 2 gear case mounting studs approximately 7 turns. (see figure 3).
13) Remove yoke retainer from yoke support. (see figure 2 for the types of yoke retainer).
14) The gear case can now be pulled down so that the belt can be slipped out between the top of of the clutch shaft and the clutch yoke. (see figure 4) and then through the space beneath the short stud; drop the belt from around the gear case.
15) Reverse the procedure in steps 15 & 13 to install the new belt.
16) Replace the pump making certain the pump lever is engaged in the notch in the agitator cam bar before securing the pump to the gear case ( see figure 5).
17) Grasp the bottom loop of the yoke spring with a pair of pliers and engage the spring with the hole in the upper gear case cover (see figure 2).
18) Replace spacer in short gear case mounting stud. Tighten the 3 gearcase mounting bolts ( finger tight only ). Next, set the machine upright and tighten the gear case mounting bolts securely. This procedure will allow the superstructure to properly align itself with the center post bearing.
19) Lay the machine on it's front to mount the 3 support braces to the gearcase baseplate. Tighten the bolts securely.
20) To adjust the belt tension properly, position the belt over the pulleys. Insert a hammer handle or some other lever between the motor mounting brackets. Rotate the motor to the left as far as it will go. Tighten the nuts holding the motor mounting bracket. Check the tension of the belt, it should deflect about 1/2 inch. (see figure 1).
21) Set machine upright. Reinstall the agitator, agitator cap, service panel, water hoses and connect electrical supply.
Mar 07, 2011 | Whirlpool Washing Machines
Won't spin
Ok the must be empty to spin. Make sure the water has all gone. Any way clean out the pump trap behind the little door at the bottom front. I assume it is a fron load . you haveny\t said what type of machine have you? Thats like saying my car wont start but what type of car is it? Once the water hs gone try spin ing the machine dry on a spin only cycle. If it wont spin then the motor brushes should be checked. You might have to remove rthe motor fort this Call for assistanve when you get this far.Good luck
Sep 05, 2010 | Washing Machines
Kenmore series 60 when on spin, water leaks
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.81860110&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Jul 05, 2010 | Kenmore Washing Machines
Water pours out bottom 90 series lady kenmore
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the following:
May 15, 2010 | Kenmore 15864/15862 Top Load Washer
Water comming out the bottom of washer
See the following:
May 07, 2010 | Kenmore 23822 Top Load Washer
During spin cycle water come out of the bottom of
See the following:
Apr 03, 2010 | Kenmore Washing Machines
The dish washer will not drain. There is water in
there is probably astuck peice of glas in the propeller. manually drain unit. take a torc screwdriver and remove screw in bottom of unit. you are removing a piece that looks like a plastic cover. now carefully spin the propeller and take out what is stuck ,put back screw then hit cancell and drain. that should do it. let me know if this was helpful
Feb 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Honda CRV-2001 accessory plug problem in main dash
I had the same problem on my 99 CR-V.
  1. Remove the ash tray
  2. Remove the cup holder tray beneath ash tray. Extend tray. There are two tabs on the bottom to push in to release. Not easy to do but if you push in one tab and pull that side out slightly it will stay unlatched while you do the other side.
  3. You should now be able to reach in thru the side of the cup holder opening and attach the nut to the back of the acc socket. You may need to use the area where the ash tray was to get a grip. Make sure it is tight or you will be doing this all over again.
  4. The acc socket cover is attached to a ring. That ring has a tab goes in a hole in the dash trim peice.
  5. Test the socket before replacing the ash tray and cup tray. You don't want to have to remove them again.
Hope this helps. I searched everywhere and couldn't find the answer so I just poked around and finaly figured out how to do it.
Apr 11, 2009 | Tomtom ONE GPS Receiver
Main seal
This is a pretty tough job to do on your own, but can be done. First step is to remove the front, then the top. Remove the rear cover plate under the console, and swing it out of the way. Unclip the top ring and remove the four suspension dampener straps, remove the top ring. Reach under the agitator, and pull up with force (dont hit yourself in the head or face with it, hurts for sure...) until it pops off (agitators on GE's just snap). Sometimes these can be a real bear to get off, so dont get discouraged. Sometimes you can put a peice of small rope or line under it and jerk it up. After you remove the agitator, you will see the drive bell. Remove the bolt on top of the bell, and once again, try to pull the bell up and off the shaft (once again, a real bear in some occasions, rope trick or puller also will work here). Once you remove the bell, the good part starts. Most of us repair persons have a special spanner tool for that nut your looking at. I believe it is a 1 7/8" nut. This nut is REVERSED THREADED, which means to remove you will spin it clockwise. These spanner nuts can be very, VERY difficult to remove. A lot of WD-40 and time. Most of the time you have to bang them off with that special tool and a hammer, but you may get lucky. If you do get that nut off, you can remove the inner tub. Be sure that the metal drive hub bolted to the bottom of the inner tub is completely tight all the way around. GE units have a very bad habit of those screws backing out and the drum getting loose causing major league noise. Now that you have removed that, you need to remove the outer drum. Remove the wires from the motor, etc. Unhook the 4 suspension rods and plastic clips by pulling the bottoms down (spring loaded) and removing them from the frame. Unhook the tub to pump drain hose, tilt the entire center section top towards the back, and swing the unit out from the bottom. Remove the outer tub by removing the hold down screws. Your seal will be in the bottom. Just pop out and replace. Here are some diagrams that might help you out.
Cabinet and Top:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=CABINET%2C%20COVER%20%26%20FRONT%20PANEL&titleID=00002&
Drum, Agitator, Basket:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20BASKET%20%26%20AGITATOR&titleID=00003&
Drive Componants, Suspension Parts:
http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=0432&modelDesc=WASHER&modelNumber=WWSE6260B3WW&documentID=G0302079&documentTypeID=PLDM&documentClassCode=PV&titleType=SUSPENSION%2C%20PUMP%20%26%20DRIVE%20COMPONENTS&titleID=00004&
Good luck, and let me know how it comes out, or if you need anything further. Good Luck!!!!!!
Jan 31, 2008 | Washing Machines
KitchenAid 24 in. KUDP02FR Built-in Dishwasher Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
